Won't REVERSE!
Old Dec 26, 2004 | 01:35 PM
Bball122's Avatar
Bball122
Default Won't REVERSE!
For the past two mornings my 6mt has absolutely refused to shift into reverse while sitting still with the clutch in. It feels like it's stuck or something. Is it just the cold? (I live in Dallas but it gets cold.)
By the way, I did a search and came up with nothing. Thanks guys...
Old Dec 26, 2004 | 01:43 PM
ssc's Avatar
ssc
maybe your reverse gear locking mechanism is malfunctioning....try this...what used to work for my old honda when it wouldnt get into reverse is that i would put it into one of the other gears first and then pop it into R.
BTW, you are pushing the shifter all the way down, right?
Old Dec 26, 2004 | 01:52 PM
nicolaycastro's Avatar
nicolaycastro
this has not happened to me either, but I have a friend with a subaru, and he told be he had to press the cluth twice sometimes.
Try it may be it helps.
Old Dec 26, 2004 | 02:50 PM
Santacruzslick's Avatar
Santacruzslick
Veteran
Maybe it's frozen. LOL
Old Dec 26, 2004 | 02:54 PM
Monsta's Avatar
Monsta
Is it possible that the clutch is wearing? It would make it hard to shift into any gear and maybe reverse is the first one to go.
Old Dec 26, 2004 | 03:36 PM
Built2shredZ's Avatar
Built2shredZ
Put it into first and roll forward a few inches then put it into reverse... Used to happen to my honda prelude...
Old Dec 26, 2004 | 03:47 PM
JCat's Avatar
JCat
Free tranny time.
Old Dec 26, 2004 | 03:53 PM
Monsta's Avatar
Monsta
Originally posted by jcn30127
Free tranny time.
I like that solution the best.
Old Dec 26, 2004 | 03:57 PM
hunter164's Avatar
hunter164
Free tranny time.
That's the first thing I thought of. I'm surprised it took this long to come out as a solution.
Old Dec 26, 2004 | 07:43 PM
ares's Avatar
ares
Veteran
well, no reason to go through major work if its something simple. 1st locks out on me occasionally, just release the clutch and back in. guess maybe the synchros are perfectly lined up or something to not go together. whatever. never been a repeated problem.
if you can NEVER get it into reverse Id call that a definitive problem.
Old Dec 27, 2004 | 06:46 AM
maximumsportZ's Avatar
maximumsportZ
Yea, that happen to me a few times in the cold. I just put it in 1st, inched up a bit then it works fine in R.
sherm
Apr 11, 2020 05:21 PM
bcoffee20
Nov 19, 2015 06:39 PM
Depravity
Oct 1, 2015 04:49 PM
Tochigi_236
Sep 27, 2015 03:40 PM
