Crashed my Black Track 350Z. Need advice
Zboy, I am so sorry to hear about your accident. That sucks. I can tell you that these new paints are usually 3 stage, which means that on my Z32 TT, when my across the street neighbor backed into the rear quarter panel, I had the whole side repainted at a good body shop. To properly match the paint a good shop will paint at least an entire side to blend properly with the old paint. You could never tell mine had even had work. I wouldn't worry much about it. If you use a good body shop, they will make you satisfied. Also, if you have a little extra to spend, it might not be a bad idea to have the whole thing wet sanded and repainted. This is obviously the best time to do it, and the good shops bake that stuff on so it is pretty tough and will look better than factory job, although maybe not quite as tough. Although, apparently Nissan's paint on this car isn't that durable anyway.
Think of it this way. It is likely to happen to very many of us eventually, so you just got yours out of the way early and thank god you weren't injured. Just be careful out there from now on. I am sure you car will look great when you get it repaired.
Sorry to hear about your misfortunes... but remember that cars are just inanimate objects in the end. This was a hard lesson for me to learn, and I am paying for it now. Just be glad that you are okay and weren't nailed by someone on the highway when you spun out.
From the sounds of it, the car wasn't damaged very badly, so it should be an easy fix. Good luck!
Be careful about the rock-scratch sugestion. Submitting a false insurance claim is a felony. Adjusters are trained to look for what is called "augmentation" and to deal with it aggressively. You don't want to make a hassle into a problem. Just take your lumps and move on.
I had the identical road condition problem with my Supra TT a few years ago. A freak snowstorm + the worn 40's on the back tires was a bad combination. I was fortunate to come upon a rest stop after two miles. Sometimes you get a break. Very close to a black ice level of grip. Sounds like you did everything correctly. Pop for the repaint and get back to enjoying the car!
I have driven my Z a few times in the snow with the stock summer tires a few times. I definitely would not go over 10 mph either!
In any case, my suggestion if you start to slip: put in the clutch immediately! You need to practice this technique to get it right. I'm an old pro so I can actually react faster than the TCS/VDC system.
If you have an automatic, shift to neutral immediately instead. It may also help to run in second or third gear and ride the brakes. The reduced torque going to the wheels will lessen the slippage, although your brakes will overheat. You can use this technique to go 2 miles like you had to.
Best of luck with fixing everything up. If you get a chance, get to a big empty parking lot with your car on summer tires and see how it slips and slides with these different techniques.
Sorry about your car! Next thing to do is concentrate on the the fix. The insurance needs to put the vehicle back in like condition. Your car with <10K miles is like new. Make sure they fix it as such. New panels are like new,repaired panels and bondo panels are not like new.
Stick to your guns and don't settle for less and you will never be able to visibly see your car was crunched.
Zboy, glad you are ok. Quick question; what kind of car did you drive before your Z?
My previous car was a Toyota MR2 Spyder. As people started to get them you would see a lot of crashes in the rain on spyderchat.com. People claimed the car was undrivable. Problem was not really with the car however, it was with drivers inexperienced with RWD cars.
Here in SoCal it doesn't rain often so after reading all the horror stories I waited for the first rain. Well, the first rain came on my way to a track event!! Actually it snowed pretty heavily then as the sun came up a bit it turned to freezing rain. We got to the track (Streets of Willow Springs) about 7:30 am and we ran the event. I watched FWD Celicas spin off all day, but never a problem with the mid engined, rwd Spyder. Sure it was more fingertip driving, but it was adapting to the much lower traction. I found the MR2 to be no problem at all in the rain.
Now sure on sheet ice, there is little you can do. But the fact that cars weren't crashing all around you tells me that probably wasn't the case. Nearly all of these types of accidents can be summed up as too low a gear with too much throttle input resulting in loss of control of the vehicle. I'm not saying that is what happened to you Zboy, but just a reminder to everyone else.
Zboy, where you in Natick this week? I just saw a black Track a few days ago, I wonder if that was you. I'm so sorry about the accident and the car, but waht really matters is that you're ok.
I drove my 300zx thru three winters with no problems (but it had the all season tires, not summer tires) and thought the 350Z woud not be too bad. But after hearing at 10 mph you're sliding, I'm a bit worried. I commute the Pike as well, but only to Framingham. Let us know how it turns out with the insurance, and hopefully you'll get your car back soon.
Eduardo
Silverstone Perfor.
Eduardo
Silverstone Perfor.
Sorry...
1. Your insurance will not go up by much, unless your under 26 yrs.
2. Park the car and drive the SUV/beater in the snow
3. If SUV/beater is not an options...SNOW TIRES
Your body damage is easy to repair and your car will look new. Black is a great color to repair, it hides imperfections.
Originally posted by Zboy
Yes my Z did pull to the right slightly when driven. Thats alignment problem, correct?
Some states have extreme paving standards due to heavy rainfall. I suspect that those who have the worst problems with their Z pulling to the right live in these states.
Dead
Sorry about your car. Here;s a few thoughts.
Your writeup sounded like you wanted prepainted new panels. They dont come that way.
If you want to repaint the whole thing, the diff will come out of your pocket.
You are lucky, in one way. Black is the only color that is perfectly matched every time. White is the hardest, and the others in-between.
I would ask the Nissan dealer where they get their damaged cars fixed, and go to that body shop.
I did almost 10k worth of damage to a 96 S-10, and the body shop was so good, the dealer couldn't tell. A great body shop is everything.
The phrase to use with your insurance for depreciation is "diminished value"
Good luck
Good luck
Sorry for your loss. A new front fender is probably cheaper to fix, than pounding out the old one. On the rear quarter though, they will straighten and fill a litlle most likely, unless the metal is ripped. I appraise cars all the time, I can tell when any car was painted during the day... at night or in the rain...it is a little harder. So here is a little advice to all of you...when trading a car, go at night in the rain...hard to pick out hail, dents, and scratches.
To the member who posted " the 350Z should handle in the snow..." I noticed you were fron Florida. Maybe you have snow belt experience....but unlikely from your response. If you have never lived through the Snow-belt winter...YOU HAVE NO IDEA!!!
Get some WINTER tires at a minimum.
Guest
Posts: n/a
There's nothing wrong with the way the car handles, nothing wrong with VDC. It's the tires!!!
Summer tires are useless below 40-50 degrees. They are sticky in warm weather and that's why they perform so well. But once it gets cold they turn into hockey pucks.
The owner's manual probably says something about it???
Bleh! Same day that I hit 10,000 miles on my Z, it gets into an accident. I was driving from Albany to Boston and it was raining. I was cruising at 60 mph on a 65 mph highway on the slow lane. It was supposed to just rain but after half an hour it started snowing.
As soon as I see snow, I slow down to 35-40 mph and look for the next gas station/exit so I can stop for the night and stop driving until it stops snowing and it is clear. I did not want to stop in the break down lane because road was bad and trucks/cars were passing very close by at high speeds. I was afraid of being hit by someone. So, I have about 5 more miles to next gas station...and then it happens... car starts sliding to the left lane and VDC tries to help to no avail..I hit the left railguard, bounce off it and hit the right one and then bounce off that one and come to a stop on fast lane facing the traffic... well good thing there was no traffic which gave me enough time to straighten the car out and pull into breakdown lane. I come out the car to see front left corner and rear left corner damaged.
Man my heart sank, one of the worst feelings.
Anyways, I am sitting down in snow by my Z for next 10 miniutes or so and then I decide to continue on to the gas station while going at 10 mph on the breakdown lane with my emergency flashers on. Engine seemed to be running fine..but there was bad noise coming from back. I went out and noticed the back part of the car was scraping against the rear tire. I try to pry it off just enough to clear the tires but could not. I didnt want to be stranded there forever so i decided to go on anyways. 1 minute later i friggin slip again to the next lane and spin around at 10 mph!!! Straighten the car out and decide to wait for help this time.
Highway mainetence guy comes along and tells me to go up 1 mile and pull up in Blandford highway maintenece facility.. So here I am driving at 10 mph in breakdown lane with the guy driving behind me. I slip two more times and almost hit the guard on the other side again with him watching. Another time, Z gets stuck in snow since they hadnt cleaned the road or put any salt/mud and road was horrible. And he actually had the ***** to tell me "What are you waiting for? We are almost there!" I am like "Dude its a rear wheel drive car and its slipping, I cant go any faster than 10 ph. Go clean the friggin road!"
Left the Z at the maintence faiclity and it was towed next day to Autobody shop. Towing people were pretty busy. Accident was being reported on that highway every 15 minutes on radio. Crushed Lincoln navigator came in teh faciltiy next while we saw another car that had veered off road and into the woods.
So how unlucky was I? Snows unexpectedly on me...I had 5 miles to the next gas station where I would have stopped for night... 2 miles to the mainietence facility...and 10 more miles till the snow would turn into rain!! It was snowing only in that 20 mile stretch or so becuase that was the highest altitude area on tha Mass Pike. ARGHHH!!!!!! And here I was for last 2 months not taking my Z out when it rains!!!
DO NOT EVEN ATTEMPT TO DRIVE THE Z IN SNOW EVEN AT 10 mph OR SLOWER EVEN IF YOU HAVE THE VDC/TCS with everything stock. Vdc/tcs can only help/aid you so much. I already knew this but I was caught off guard in the situation and after that there wasnt much I could do.
How much do you people think my insurance will go up by? Right now I am paying $1300 per year for the Z.
Also, any advice/help in dealing with the repair? I got it towed to the autobody shop right next to the dealership I bought the Z at. I know a repaired car is never exactly the same as a new one BUT...what can I do to make sure that it comes as close to it as possible? I dont want any repainting done because I know car loses value once its been painted over. How can I avoid this from happening? I would really appreciate any advice/help I can get from people on this forum. Thanks
Man my heart sank, one of the worst feelings. Anyways, I am sitting down in snow by my Z for next 10 miniutes or so and then I decide to continue on to the gas station while going at 10 mph on the breakdown lane with my emergency flashers on. Engine seemed to be running fine..but there was bad noise coming from back. I went out and noticed the back part of the car was scraping against the rear tire. I try to pry it off just enough to clear the tires but could not. I didnt want to be stranded there forever so i decided to go on anyways. 1 minute later i friggin slip again to the next lane and spin around at 10 mph!!! Straighten the car out and decide to wait for help this time.
The OE RE 040s are "Summer" tires only and will not handle any snow or ice period. If you run into snow or ice, get off the road ASAP and call for a flatbed from Nissan to get your car out of there, it will be undrivable. This a situation where no amount of electronic devices will help you until you change out the tires for dedicated snow or all season tires. I think Nissan should be notified about this problem with the standard tires, especially for Z owners in the snow belt.
This nothing to do with rear wheel drive, the tires have 0 traction in winter weather and I believe snow belt owners should be assisted to buy new tires since the RE 040s already had a bad reputation when they were chosen as Original Equipment. If you've visited Tire Rack lately you may notice they recommend Michelin Pilot Sport A/Ss as replacements for the Zs with 17" wheels. I was very disappointed when I found out what tires we were getting as standard equipment. This accident confirmed my fears about them and I think Nissan should be hearing from a lot of us about this failure of the O.E. tires.
Boomer
Originally posted by ImmortalisD
1st off, sorry to hear about your accident. Luckly you were driving slow and it sounds like you didnt get hurt at all.
Have you ever driven other rear wheel drive sports cars in the snow? I'm not picking on you, just trying to get an idea if the Z is that much worse than other similar cars. I used to drive a Mustang GT in the snow in upstate NY and I never thought I could own a car that was worse than that. Now that I'm getting a Z in NJ, you story has me considering a "Winter vehicle" as backup.
Originally posted by JDZ
One question. Did you try counter steering or any other manuever to straighten out the car?
