what is the cold weather tire pressure for the Z?
Old Nov 8, 2002 | 12:27 PM
fatZo's Avatar
fatZo
Default what is the cold weather tire pressure for the Z?
Old Nov 8, 2002 | 01:14 PM
SunsetZ's Avatar
SunsetZ
Same as the warm weather pressure, 35 psi for the 18" Touring.
Old Oct 23, 2003 | 10:59 AM
mxpx_8's Avatar
mxpx_8
Mine are at 35 when it is warm, but for the past two days when I first start up the car I get the annoying beeping for low PSI (28). That is going to get old quickly.
Should I put more air in them? Or should they be at 35 PSI when cold?
Old Oct 23, 2003 | 11:53 AM
John's Avatar
John
Put more air in them.
Old Oct 23, 2003 | 12:03 PM
mxpx_8's Avatar
mxpx_8
RGR that.
Thanks!
Old Oct 23, 2003 | 03:37 PM
WayneTN's Avatar
WayneTN
For any season, set to the desired pressure when the tire is cold and let it go up when it warms up (but don't let any air out when it warms up). It should cool off and go back to the set pressure.
WayneTN
Old Oct 23, 2003 | 03:39 PM
bobS's Avatar
bobS
I read somewhere that every 10 degrees the temp falls from when u filled up your tires, you will lose around 1lb. of tire pressure, can anyone confirm this? i can't remember where i read it.
Old Oct 23, 2003 | 06:12 PM
archman350z's Avatar
archman350z
Yes. It's a general rule of thumb because it depends on many factors, but this is a close estimate. I use it the opposite way to tell how hot the tires are running on the track.
I hate that low tire pressure alarm. It sounds like something is seriously wrong when all it really is, is that the tires are at 28 PSI. It seems to go off each time you open and close the door too. What's next, an inflatable dummy that beats you over the head when it reaches 25 PSI??
BTW: I had my tire pressures still set at 30 PSI cold from the track event the weekend before. The temperature dropped from 70*F to 50*F, so I lost 2 lbs. The magic formula works!
Old Oct 24, 2003 | 05:43 AM
bobS's Avatar
bobS
hahah sweet...yea from my personal experience the formula seems to be right to..
Old Oct 24, 2003 | 06:38 AM
mxpx_8's Avatar
mxpx_8
So let me get this clear. You should always have your pressure set to 35 when the tires are cold? Therefor, I should inflate my tires up 7 psi now because when I start the car for the first time in the morning the psi reading is at 28.
True or not?
Thanks again!
Old Oct 24, 2003 | 11:12 AM
archman350z
Correct! The optimum tire pressure is given on the car. This is the tire pressure that will yield the best characteristics, including tire wear, heat generation, responsiveness, and load carrying capacity.
BTW: Under-inflated tires were found to be a significant cause for many of the Explorer roll-overs!
lapham3
Oct 7, 2022 03:15 PM
sales@czp
Sep 23, 2019 03:30 PM
