n2
Old Jan 23, 2005 | 04:01 PM
the7ferret's Avatar
the7ferret
Default n2
Where can one find nitrogen around riverside to fill ones tires?
Or even is there a place which lists all the places to get nitrogen for your tires?
Old Jan 23, 2005 | 04:04 PM
FairladyZ's Avatar
FairladyZ
nitrogen?
Old Jan 23, 2005 | 04:08 PM
kcobean's Avatar
kcobean
he he...Boy there has been lots of debate around this subject. I think it was ultimately decided that using nitrogen on car tires has an un-noticeable effect in all arenas including pressure, moisture effects on the rim, inflation duration, etc.
What are you hoping to accomplish by doing this?
Old Jan 23, 2005 | 04:23 PM
the7ferret's Avatar
the7ferret
I would like it for the pressure. I see my TP rise at least 4 PSI according to TPS.
Old Jan 23, 2005 | 06:10 PM
badtziscool's Avatar
badtziscool
I thought gases expand at a constant rate? Nitrogen filled tires would expand just as much as air considering the street application.
Old Jan 23, 2005 | 07:25 PM
funkdamonkman's Avatar
funkdamonkman
I can tell you how to get your tires 78% full of nitrogen...
Old Jan 23, 2005 | 08:55 PM
the7ferret's Avatar
the7ferret
Yea air!
The reason I want nitrogen is that it is "dry" no water vapor thus the water vapor wont affect tire pressure.
Old Jan 24, 2005 | 11:59 AM
MrLoutish's Avatar
MrLoutish
I don't know much about using Nitrogen in tires but I do have some experiance with gasses, nitrogen in particular as I'm a chemist. Just so you know
"Dry" gas is a realtive term and short of using regaent grade or better source gas you not going to see any major differences from compressed air.
Old Jan 24, 2005 | 02:18 PM
kimara's Avatar
kimara
What you are trying to accomplish, seems to be a tad bit extreme. But I hope you accomplish your task.
Old Jan 24, 2005 | 02:32 PM
TampaZ's Avatar
TampaZ
My tires are filled with nitrogen. Most high-end shops nowadays use nitrogen instead of air for many reasons. Supposedly the air leakage from the tires is limited to 1/4 the time. Costco filled my new tires with nitrogen for no additional cost.
