how do you launch??
Old Nov 20, 2002 | 04:06 PM
dragonbz99's Avatar
dragonbz99
Default how do you launch??
ok... im new at stick shifting so when i launch my car do i just rev it to 4000 then pop the clutch???
Old Nov 20, 2002 | 04:54 PM
PistolPete's Avatar
PistolPete
If you dump the clutch at 4k and you have the stock tires, you will light 'em up all the way through first. Fun, but not fast.
Even if you dump and 2k and get into the gas you will spin your tires excessively. If you want to dump the clutch do it at 2k or so, and wait 'till it hooks before you give it gas. If you hammer the gas anywhere in first, it'll break free.
Old Nov 21, 2002 | 11:07 AM
stx's Avatar
stx
Don't dump the clutch. Let it out enough to get you going with out spinning the wheels. Once your moving then let it complete out.
Old Nov 21, 2002 | 01:02 PM
BullishZ's Avatar
BullishZ
Umm.. you mean drive normally?
Old Nov 21, 2002 | 01:52 PM
stx's Avatar
stx
Talking
I was just joking
Old Nov 21, 2002 | 01:55 PM
Zaphod 350z's Avatar
Zaphod 350z
actually, you don't want to rev and hold it. you want to "blip" the throttle and time your clutch release with the downstroke of the gas pedal. by hitting the gas and holding, you open the injectors and put the motor under compression for the first instant when you hit it, but it tapers off once you hold the throttle. by actuating the gas pedal and releasing the clutch during a depression, you are engaging the gear while there is a load on the motor and you will take off faster and will be less likely to bog the gear.
give it a try.
Old Nov 21, 2002 | 02:00 PM
fdao's Avatar
fdao
give it a try.
I agree. That's how I launch at the track. However, for me, I launch at the second yellow light. By the time the car rolls, the green is already lighted.... .514-.528 R/T, with a good hook up!
Old Nov 21, 2002 | 02:04 PM
Zaphod 350z
I'll have to get readjusted. been launching AWD for a while now. last yellow launch. second yellow = red light with AWD!! I'll definitely be investing in some drag radials.
btw- what did you run?
Old Nov 21, 2002 | 02:11 PM
VaGentleman's Avatar
VaGentleman
Originally posted by fdao
I agree. T. .508-.514 R/T, with a good hook up!
I edited...to include my times
Old Nov 21, 2002 | 02:59 PM
fdao's Avatar
fdao
VaGentleman,
Nice R/T
Old Nov 21, 2002 | 03:01 PM
fdao's Avatar
fdao
With 35 psi at all corners, Temp of 80F, Humidity >60%, sealevel, and 60Ft time of 2.3+, 1/4 mile was 14.6 @ 98+ MPH .
Old Nov 21, 2002 | 03:49 PM
BRONXWARRIOR's Avatar
BRONXWARRIOR
Talking
ask NASA they have a lot oif experience
Old Nov 22, 2002 | 05:49 PM
N74DV's Avatar
N74DV
Default auto launch
whats the best method of launching the auto trans Z ?
bcoffee20
Nov 19, 2015 06:39 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
