The factory shift knob
Old May 11, 2005 | 07:20 PM
NA350Z's Avatar
NA350Z
Default The factory shift ****
How the hell do you get the factory shift **** off, i want to change it?
Old May 11, 2005 | 09:59 PM
yobri's Avatar
yobri
If you're talking about an MT, you'll want to clamp down the shifter rod (underneath the shift boot) before twisting off the ****. If you have an '04 or newer 350Z, supposedly the **** is a lot easier to remove than with the '03's (mine was on TIGHT ).
Old May 11, 2005 | 11:24 PM
Fiction520's Avatar
Fiction520
Vice grips on the shifter rod, vice grips (with many layers of towels) on the squarish bottom part of the shifter. Righty-Tighty, Lefty-Loosey. Got mine off with no marks.
Old May 12, 2005 | 12:08 AM
Z BOY's Avatar
Z BOY
can use radiator tubing to protect shifter; strap wrench is great for turning ****.
Old May 12, 2005 | 02:16 AM
nbdyfcnsqnc's Avatar
nbdyfcnsqnc
Mine had red loktite (!!!), and it was nearly impossible to get off. So I got my brother to do it. He broke the shifter at the anti-noise joint, drilled a hole in it, mounted it in a lathe, and broke the **** loose using a pliers grabbing onto a belt wrapped around a towel. (It's a home-made strap-wrench I think.) Then he re-threaded it to get rid of the extra loktite.
Old May 12, 2005 | 10:09 AM
elms350Z's Avatar
elms350Z
wow that's crazy! I took mine off by hand while driving in my 05. Just kidding a lil friendly humor, good luck though.
sherm
Apr 11, 2020 05:21 PM
sales@czp
Sep 23, 2019 03:30 PM
Depravity
Oct 1, 2015 04:49 PM
