best alignment spec to avoid feathering?
Old May 14, 2005 | 09:17 PM
wutafobb's Avatar
wutafobb
Default best alignment spec to avoid feathering?
recently lowered my car with tanabe gf springs. been lucky with feathering issues, didnt have it until 13000 miles. Just got a set of new so3. Want to find out the best spec to aligned my car that will minimize feathering until i get coilovers. thanks guys, help will be appreciated.
Old May 15, 2005 | 06:47 AM
mario60185's Avatar
mario60185
Chicago Realtor
well first advive is go to an alignmant shop who does it the old school way, all manually. no lasers. I just installed the nf 210's and i have no toe and maxed out adjustments for camber front and rear. im at -1.5* camber front and -1.75* camber in the rear. basically the less camber you have the better youll be as far as tire wear. So see what your max adjustments are and go from there. a good # for decent wear and good handling will be somewhere around -1.25 and -1.5 front and probably the same for the rear.
Old May 15, 2005 | 09:38 AM
myz8a4re's Avatar
myz8a4re
i agree, the more positive (in spec) you run your camber the less feathering you will see. also get your toe as close as possible to "0", favoring the "in" setting if you cant get it to "0", leaving no toe out. the less agressive camber causes less inner tire edge wear. the heavier wear is where the feathering starts to show 1st......these 2 settings together are the only known adjustments to date that appear to help the feathering. too bad we dont have caster adjustment!
-justin
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
