Even 245/245 tire setup?
I've been reading a lot about possible tire combinations but have heard conflicting information with regards to using an even tire setup. Just for reference, I have a Performance model with 18" wheels.
On one hand, I have heard people recommend using an even 245/245 front & rear setup will decrease understeer and improve the car's handling. This should be possible since both wheels are 8" across. This option is especially appealing to me since I have the tire feathering issue, and the thought of being able to rotate the front and rear tires is awfully appealing.
On the other hand, I have heard people say that doing this will screw up your ABS, VDC, LSD, etc.
What's the correct opinion??
Honestly, this board has great knowledge and they could probably answer the understeer/handling question. But in regards the the VDC, I'm a mechanical engineer and I can't give you an answer. I could think about all the factors I see and give an educated guess, but only the engineers that designed it can tell you all the variables used in the VDC design and what would be affected. My point, I would not say there is an correct opinion here, because its just that, an opinion. Of course, there's always the trial and error method where you could put those tires on an see/feel.
350Z_Al
Oct 29, 2020 07:44 PM
