Ac Nasty Smell !?!?
Old Jun 7, 2005 | 07:56 PM
Loic's Avatar
Loic
Angry Ac Nasty Smell !?!?
Every time I turn off the AC, I get a nasty smell out off the vents…The smell is so bad that I have to open both windows for 5 min…If I drive the car with the AC on in the evening, the smell will come-up the next morning if I turn the AC off…
You may occasionally get some bad odors while switching the AC on and off but that smell is far stronger…
What can I do to take care off that issue? Any ideas?
Thanks,
Loïc
Old Jun 7, 2005 | 08:08 PM
Kolia's Avatar
Kolia
Nissan should have an aerosol to get rid of this. It's mildew in the vents.
Have it checked out. Then, when you use the AC, make sure you let the fan run for some time after you stop the compressor, to dry the system.
It should never return.
Loic ? Frenchy ? Are you french ? Salut !
Old Jun 7, 2005 | 08:16 PM
iheartZ's Avatar
iheartZ
always try to turn off your ac a couple minutes before you shut down your car. itll decrease the condensation.
Old Jun 7, 2005 | 09:38 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Sometimes you can kill the mildew by blasting dry heat (A/C with heater) for a long time.
If the smell lingers, Ozium is a pretty good product to neutralize the odor. For 1-2 days it will smell like "ozium" but after that, the smell will disappear altogether. It's sorta like Febreze on crack.
Old Jun 8, 2005 | 04:00 AM
Forrest80's Avatar
Forrest80
Nissan dealer told me your vents will grow mildew in them if you selectivly do not let any outside air in and just have the recirculation option selected, he said if i used the outside air option hte most i woudlnt have the problem.
So far i have not noticed a really nasty smell, but then again i only had hte car 350 miles hehe
Old Jun 8, 2005 | 08:20 AM
kamikaZ's Avatar
kamikaZ
3FIFTYZ
I have that mildew smell too, ill try the suggestions on here.
Old Jun 8, 2005 | 11:02 AM
crjpilot's Avatar
crjpilot
Mine does it too. Smells pretty crappy sometimes. It seems to be lessened like iheartZ said if you shut off the AC a little while before shutting off the car. Other than that, it seems to be a normal occurance.
Old Jun 8, 2005 | 11:29 AM
SeanG's Avatar
SeanG
The smelly sock smell will eventually go away on it's own. Both my 03' and 04' Z's and Murano and Mitsu Eclipse had this smell brand new off the lot when the air had been running for awhile then shut off, which would of course not be due to mold in the vents.
Mold would need quite abit of consistant moisture to grow, the A/C Compressor removes most of the moisture from the OUTSIDE air, that is why it comes on for defrosting or removing fogging of the windows. It's not a swamp cooler.
I heard it was from the new A/C components putting off vapors and that the smell would go away depending on the frequency of use. All my cars had the smell go away on it's own within 6 months. My new central air system in my home did the same thing when the compressor shut off and the fan continues to blow. The smell went away with it as well.
Old Jun 8, 2005 | 03:37 PM
mwest300zx's Avatar
mwest300zx
My company services hunders of car dealers in NJ and Pa. One of the things we do is deodorize vehicles with the same problem you are describing. I just responded to a similer post on the roadster sight. Take a look at it. It should help you.
Old Jun 8, 2005 | 03:43 PM
MySunset350Z's Avatar
MySunset350Z
i have to deal with the same nasty smell. goes away after a while, but its getting annoying.
Old Jun 9, 2005 | 09:35 PM
Loic's Avatar
Loic
Could you put a link to the post you're refering to?
Thanks,
Loic
Old Jun 9, 2005 | 09:37 PM
Loic's Avatar
Loic
Alexandre, comme tu l'as devine (c'etait pas bien dur...) je suis Francais; J'habite a LA depuis maintenant 5 ans...
Loic
Old Jun 9, 2005 | 09:47 PM
pyindeem's Avatar
pyindeem
Every car has its own smells, ex. all hondas smell the same after you turn the ac on (well, at least here in TX), I suggest the product called hmm...Ozium. It worked for my prelude for few months, however the moldy sock smell do come back
3vilbunny
Jul 18, 2017 05:10 PM
smithmt3
Sep 11, 2015 08:25 PM
PureR3d
Sep 10, 2015 06:23 PM
s9am_me
Apr 10, 2003 10:05 PM
