Noisey Pulley Belts
Old Sep 30, 2005 | 10:40 AM
ecorona6's Avatar
ecorona6
Default Noisey Pulley Belts
I just installed my UR Pulley's (minus Crank Pulley, will install later) and now the belts squeak very loud when the car is running. I only installed the Alternator & Power Sterring Pulley and used the factory belt.
Does any one know if I should either tighten the belt or loosen the belt to stop the squeak! Or should I be using the new belts UR provided me even though I am not using the crank pulley?
Thanks......
Old Sep 30, 2005 | 05:53 PM
Ztalker's Avatar
Ztalker
you should go ahead and install the crank pulley with the new belts....and see what happens...i also installed the UR crank pulley with the new belts a couple of months ago and i haven't had any squeaks since i re-tightened the belts last month. The new belts will need adjusting after about a month.... you don't want overtightening initially.
NOTE: your new belts come short...your not supposed to use them if your keeping the factory pulley.
Old Oct 1, 2005 | 05:14 PM
ecorona6's Avatar
ecorona6
Thanks Ztalker....your info will help!
Fixxxercask
Nov 9, 2015 11:10 AM
Calinismo350z
Sep 14, 2015 04:04 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
