Heater goes cold when car stops
Old Oct 18, 2005 | 09:44 AM
Bryan H's Avatar
Bryan H
Default Heater goes cold when car stops
Anyone else have this problem? Heater works perfectly fine, but then at a stoplight, it starts blowing cool air. It's my wife's car, so I don't drive it everyday, but I know it didn't used to do it.
Old Oct 18, 2005 | 11:31 AM
VandyZ's Avatar
VandyZ
Air bubble in the coolant lines. Has any work been done on the car that required a fluid flush / change/ top off?
Old Oct 18, 2005 | 11:43 AM
Badmonkey's Avatar
Badmonkey
+1 ^^^^ Check the coolant level.
Old Oct 18, 2005 | 12:20 PM
Bryan H's Avatar
Bryan H
Nope. No work done at all. I'll check the level, but I wouldn't think any impact on the heater should be felt at coolant levels that are sufficient enough to keep the coolant indicator light from coming on. Although, I do occasionally hear coolant "swooshing" when I first accelerate from a stop. Anything else?
Old Oct 18, 2005 | 03:32 PM
azaz's Avatar
azaz
+2 your coolant is low and has an airpocket.
Old Oct 18, 2005 | 05:02 PM
alty319's Avatar
alty319
airpocket, been there before
Old Oct 19, 2005 | 05:11 AM
Bryan H's Avatar
Bryan H
OK...seems like airpocket is the consensus. Is there a method for "burping" the coolant system, or just add coolant?
Alty - you had the same problem?
Chris350z03
Oct 8, 2023 07:19 PM
etkms
Jun 19, 2022 06:30 PM
pslamp32
Feb 8, 2017 09:07 AM
AbyteZero
Sep 22, 2015 09:17 AM
Darkspy
Sep 7, 2015 09:09 PM
