Is there a way to tell if my car is 2004 or 2004.5?
Old Jun 12, 2006 | 11:23 PM
lbald626's Avatar
lbald626
Originally Posted by jmwlenz
so if I have knee pads I have an 04.5? Doesnt 02/05 seem a little early to be an 04.5? any other more definitive way to tell, like VIN? Someone posted earlier that 6000+ VIN is 04.5?
Your production date is 04/04, which should make it a 2004.5
Old Jun 13, 2006 | 07:26 PM
jmwlenz's Avatar
jmwlenz
Yes the car has the shoulder extensions on both sides, knee pads, and I made a mistake! The manu date on the door sill shows 04/04 not 02/04. Its looking like its a 04.5
Old Jun 14, 2006 | 01:04 AM
SPK_W_ME's Avatar
SPK_W_ME
10/03 is the first of the 04.5's at least for the G35's it's that way -- mine is.
Old Jun 14, 2006 | 03:52 AM
DavesZ#3's Avatar
DavesZ#3
I originally found the official distinction between the two on the nissan-tech.com site. You can tell in the VIN numbers:
2004 Nissan 350Z Coupe/Roadster (Coupe VINs up to D*4T160000,E*4T060000) (Roadster VINs from D*4T102001 to D*4T110000 & from A*4T002001 to A*4T010000)
2004.5 Nissan 350Z Coupe/Roadster (Coupe VINs from D*4T160001, E*4T060001) ( Roadster VINs from D*4T110001, A*4T010001)
Old Jun 14, 2006 | 09:01 PM
Forever Z's Avatar
Forever Z
I could be totally wrong but I thought that all 350z's prior to '04.5 were built at the Oppama plant and the 2004.5's were built at the tochigi plant. If so just check your vin. If the 11th digit of your vin is T (Oppama plant) it's an '04 if it's M (Tochigi plant) it's an '04.5.
Old Jun 14, 2006 | 09:03 PM
Forever Z's Avatar
Forever Z
double post
Old Jun 16, 2006 | 08:07 AM
#15Blade's Avatar
#15Blade
So, if I am understanding this, a roadster, with a vin ending with A04T005525 would be a 2004.5? As as a follow on question, as a 2004.5 it's less likely to have feathering / tranny issues, correct?
Thanks for the help.
Old Jun 16, 2006 | 09:44 AM
DavesZ#3's Avatar
DavesZ#3
No, the serial numbers on the 2004.5 Roadster start at 110001 or 010001 and go up (actually, use the last 5 digits so it's 10001 or higher).
The 2004 Roadsters are between 102001 and 110000 or between 002001 and 010000 (again, last 5 digits 02001 to 10000).
I have a 2004.5 and it had feathering. It did appear that there were less complaints about the 2004.5 models than the 2003/2004's but there was no guarantee just by having a 2004.5 that you wouldn't see feathering.
Old Jun 16, 2006 | 02:44 PM
MeetJoeAsian's Avatar
MeetJoeAsian
does anyone definately have a 2004 model? one without the knee pad and etc...??? the 10th digit of the VIN wil give you your year number, 4=2004, 3=2003, etc...but, again, does anyone have a 2004.0 model?
Old Jun 16, 2006 | 03:40 PM
Wendy's Avatar
Wendy
L A d y z 3 3
i learned something from this thread! cool!
Old Jun 16, 2006 | 06:30 PM
DavesZ#3's Avatar
DavesZ#3
I have a 2004.5 and it was built at Oppama. If I remember correctly, the switchover occurred around the first of the calendar year but the production of the 2004.5's had started in Nov or Dec.
Old Jun 17, 2006 | 01:05 AM
Forever Z's Avatar
Forever Z
Like I said, I could be wrong. My bad. I do know the switch to Tochigi happend in Jan. Just wasn't too sure when the '04.5's were manufactured.
etkms
Jun 19, 2022 06:30 PM
Ronso
Oct 30, 2015 12:39 PM
3vilbunny
Sep 13, 2015 12:31 PM
h8redlights
Sep 11, 2015 07:57 PM
