TRUNK SPACE!!?? help!!!
I have a large (28" x 20" x 8") hardside suitcase that fits easily under the strutbar. That along with the wife's makeup case, a small ice chest and a couple of soft bags easily fit in the back. Enough for the two of us on a 5 day stay.
Originally Posted by LoveMyLiFe22
I am getting a 350Z for xmas.. but I am going to be traveling Alot.. how is the trunk space.. is it nearly immpossible to put a suit case in the trunk? any information about available space in the car to travel would be great! thanks! Nikki
Originally Posted by sp1kez
mecinoid...how did you do that?
2) Cut off the locking tabs, leaving the hooks on the bottom
3) Built a land on the top out of JB Weld to put Velco hook
4) Took out Sub-woofer mounting plate. You have to take the glovebox latch off and unhook all of the locking tabs on the panel to get it to pull away from the Sub-woofer mounting plate and get to the screws.
5) Lined the inside of the huge cavity with black trunk carpet from Walmart. ($10)
Took about an hour.
