Blind Spot
Old Jan 6, 2006 | 07:27 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
If you see your rear fenders in your mirrors, they are not adjusted properly.
Once the mirrors are adjusted properly it's not really an issue.
Chris
Old Jan 6, 2006 | 08:11 AM
Z_Driver's Avatar
Z_Driver
Master
Chris
I agree - However, backing out of a parking spot with a SUV next to you can be challenging in any car.
Old Jan 6, 2006 | 08:53 AM
Johnny225's Avatar
Johnny225
In any vehicle, the blind spot can be entirely eliminated. This is how you do it:
Go to some residential area where cars are parked on the side of the road. Act as if that car is in the next lane, either left or right. Then move so that the car is in your blind spot. Stop the car. Adjust your mirrors to have the car fully inside your mirrors. Usually, this means moving the right-hand side mirror almost all the way out. I have mine to it's maximum right position. Another trick you can use(although not as good), is to lean over to the middle of the dash, and adjust the mirror so that you can no longer see your car. For the drivers side, move right next to the window, and do the same things. This works, and is especially useful in SUV's. However, a little different strategy is used. Because the mirrors are so far out, you will not be ablew to see far behind you. So you have to use your rearview mirror as well. The ideal configuration is that when the car starts moving out of your rearview mirror, it starts moving into your sideview mirrors, and when it starts moving out of your sides, you can see it through your peripheral vision.
Johhny.
Old Jan 6, 2006 | 11:07 AM
TheZFan's Avatar
TheZFan
Thank you so much for all of your feed back. but this Z im getting already has a monitor, how much for the rearview cammera ?0_o and its a 03 Track. so no option of putting my top down even tho some times i wish i could get a roadster. but i hear those things droped in performance.
Chris350z03
Oct 8, 2023 07:19 PM
pslamp32
Feb 8, 2017 09:07 AM
ablaine
Nov 29, 2016 10:13 AM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Ronso
Oct 30, 2015 12:39 PM
