Took for removing (plastic clips on) front bumper?
Old Feb 13, 2006 | 10:50 AM
d!abolic's Avatar
d!abolic
Default Took for removing (plastic clips on) front bumper?
Which tool should i use to remove the plastic clips that have to be removed before the front bumper can come off? I'm referring to the ones that meet the edge of the hood. Someone suggested using a flat-head screwdriver, but a friend and i tried and found it near-impossible.
Old Feb 13, 2006 | 11:20 AM
alan00000's Avatar
alan00000
Some come off easy some you just RIP right off , my brother used a scre driver and worked half the time.
Old Feb 13, 2006 | 11:23 AM
manofsteele2003's Avatar
manofsteele2003
I had the same problem, until I figured it out. You use the screwdriver to pop up the center of the clip then you pry up the base of the clip and they come right out.
Old Feb 13, 2006 | 11:41 AM
westover's Avatar
westover
Default pop-up clips
The secret to the pop-up clips at the edge of the hood and everywhere else you find them on the car is to only pull up the center portion about half of its length. If you pull the center portion all the way out and then tug on it the bottom of the center portion expands and it is nearly impossible to get out. The same is true if you do not pull the center portion out enough. It will grip the outside portion and be hard to remove. With the center portion pulled out about half-way you should be able to slip a fingernail under the edge of the outside portion and half it pop right out into your hand with very little effort. Experiment a little with the center portion pulled out to different lengths and you will see what I mean. You only need a tiny flat blade screwdriver to barley lift the center portion. The rest is finger tip easy.
Old Feb 13, 2006 | 12:04 PM
XtaZee's Avatar
XtaZee
As others have said, the trick is to lift up the center portion using a samll screwdriver, then the rest will pop out easily.-
Old Feb 13, 2006 | 12:18 PM
ClaytonC01's Avatar
ClaytonC01
they actually have tools for those.. not sure exactly what theyre called, but theyre used to pull door panels too... just FYI...
Justin100
Nov 25, 2021 06:26 AM
issyz
Jul 2, 2017 03:04 PM
kyin
Oct 15, 2015 05:54 AM
Stevo Z
Oct 3, 2015 09:14 PM
