I got stuck, dang LSD!??
Old Feb 15, 2006 | 07:34 PM
JG 350Z's Avatar
JG 350Z
Default I got stuck, dang LSD!??
Got caught a little off guard coming into this parking lot at an awkward angle and felt the total loss of traction as one of the rear tires came off the ground. At first I thought I had slipped into neutral but then was like WTF? Let it roll back, regained traction and gave it a little more throttle to keep moving past the incline.
What happened? I thought the other wheel should have kicked in??
Old Feb 15, 2006 | 07:47 PM
JPsZ's Avatar
JPsZ
the viscous lsd won't work in that situation. our factory lsd uses fluids to lock both tires. not enough load resistance in that situation to lock both tires. thats why we should get a real lsd.
Old Feb 15, 2006 | 08:16 PM
NeoRacer_106's Avatar
NeoRacer_106
I hear the Neon SRT has a real LSD and KNIGHTRIDERtmturbo booster.
Old Feb 15, 2006 | 08:27 PM
jakesford's Avatar
jakesford
A neon gets a quaife and we get ****...
Old Feb 16, 2006 | 10:23 AM
Jeep_350Z's Avatar
Jeep_350Z
when a tire comes off the ground on any LSD there is not going to be enough pressure on the clutches to turn the tire on the ground. You would need a locker to make both tires turn.
Old Feb 16, 2006 | 12:59 PM
showstoppertk's Avatar
showstoppertk
yup, thats why real off-road vehicles have a locking diff.
Old Feb 16, 2006 | 01:49 PM
StillAlive2029's Avatar
StillAlive2029
how did it come off the ground?
Old Feb 16, 2006 | 03:57 PM
showstoppertk
thats a good question...
Old Feb 16, 2006 | 04:34 PM
JPsZ's Avatar
JPsZ
he was probably going in or coming out of a sloped driveway (i.e. gas station, fast food place) with his car at an angle, causing 1 rear tire to be off the ground. my car does this alot, more cause its lowered now.
Old Feb 16, 2006 | 04:49 PM
showstoppertk
I hope your right. I once saw this guy coming down a ramp with no barriers/guards on either side and he somehow drove the front left wheel off the ramp. so basically he had his Z bottomed out on god knows what part of his undercarriage with 2 wheels in the air. that was a sickening sight.
Old Feb 16, 2006 | 05:30 PM
overboostedtoy's Avatar
overboostedtoy
I have a set of Hotchiki sway bar. Anytime I go in/our a parking lot or anything w/an incline, one of the rear wheels will be off the ground. That might be what he was experiencing. I have open diff but I thought VLSD or any LSD is supposed to hook up both wheels and eliminate being stuck.
Old Feb 16, 2006 | 05:36 PM
bacalhau16's Avatar
bacalhau16
yes, but like they said, it wont work if there isnt enough weight on the system. If a tire is in the air, there is no weight to have the clutches work. So i can definitly understand how this happend. Kinda funny too!
Old Feb 16, 2006 | 07:03 PM
JG 350Z's Avatar
JG 350Z
Yeah on an incline coming in at an angle most cars with tight suspensions and stiff unibodies will bring the inner tire off the ground. Depending on the steepness of the incline of course.
Its also like jacking up one the front wheels and watching the jack lift both front and rear tires.
Thanks for the info guys.
Old Feb 17, 2006 | 07:36 AM
overboostedtoy
I got stuck quite a few times already. That's kind of embrassing to have a high horsepower sports car stuck w/one wheel spinning, looks like a sitting duck.
Old Feb 17, 2006 | 02:43 PM
tware's Avatar
tware
doesnt the quaife also require load to lock the gears?
Old Feb 17, 2006 | 03:06 PM
Lemans350's Avatar
Lemans350
here we go
http://auto.howstuffworks.com/differential8.htm
"The Quaife is extremely strong and durable and since the Quaife is gear operated, it has no plates or clutches that can wear out and need costly replacement"
http://www.quaifeusa.com/
Old Feb 17, 2006 | 03:26 PM
Resolute's Avatar
Resolute
The gears don't "lock", but yes, both tires must be loaded for the worm gears to maintain their bias ratio. Dogleg a Quaiffe and you won't have any limited slip action.
A clutch type does not need to have both tires loaded, and would have helped in his situation. The clutches are locked by the rotation of the ring gear to push apart the ramps inside the diff case.
Will
Old Feb 17, 2006 | 08:28 PM
tware's Avatar
tware
oh, I was thinking it was some sort of helical cut gears that would bind under load, I must be thinking of something else.
Old Feb 18, 2006 | 07:31 AM
RBlover69's Avatar
RBlover69
the nismo lsd would slove this right....i would love a 2 wheel drive always on situation lmao
Old Feb 18, 2006 | 07:38 AM
oman's Avatar
oman
All I saw was NEON and startetd Laughing! He said Neon hahahahahaha! who drives a neon hahahahahahah!!! uhhhhh that was great he is in a sports car forum talking about a neon!
