Factory Shift Light...
Old May 22, 2006 | 11:00 AM
roast's Avatar
roast
I pretty much only use my shift light when drag/street racing. I like it just fine. It serves its purpose and works well for me.
I think it would be cool if you could install a buzzer to optionally use instead of the light, too.
Old May 22, 2006 | 04:45 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Originally Posted by Z_freak
6500 rpms....works great
What do you mean 6500 rpms? Why would you set it so low.. especially on an 06? Mine's set at 7000 rpm..
Old May 23, 2006 | 03:41 AM
Kolia's Avatar
Kolia
I also set mine at 6,500rpm.
At WOT, be the time it starts blinking at 6,000 and I reach for the shifter, it's almost at 7,000rpm....
Old May 23, 2006 | 05:26 AM
Santacruzslick's Avatar
Santacruzslick
Veteran
I set mine at 7k, it starts blinking at 6500 and goes solid at 7.
Old May 23, 2006 | 09:53 AM
Ayankees2772's Avatar
Ayankees2772
i have the non rev up...set it at 6700....light comes on at 6400
Old May 23, 2006 | 01:04 PM
3hree5ive0ero
Retired Admin
I set mine at 7000 is because it'll come on at 6500. By the time I shift, it'll be at 6600, so I'm good. The only time I get there is when I'm going full throttle which doesn't happen in regular shifting so I don't need the light.. Plus, it's annoying when the light blinks at you for 500 rpms..
Old May 23, 2006 | 08:57 PM
nth.zed's Avatar
nth.zed
Wait a minute… what’s your hand doing off the shifter? (Make no mistake, I am not assuming you are “doing anything” with your hand while off the shifter)
Old May 23, 2006 | 10:11 PM
3hree5ive0ero
Retired Admin
+1.. your hand shouldn't be off the shifter anyway if your redlining
Old May 24, 2006 | 03:11 AM
Kolia's Avatar
Kolia
I'm driving...
The Fast and the Furious type movies should not be used as driving techniques references. One hand at noon on the wheel and the other on the shifter?
Both hands go on the steering wheel for maximum control and feed back. Going for the shifter only at the moment you actually shift and then go back to the wheel.
That's what you'll learn in advanced driving classes.
Old May 24, 2006 | 06:28 AM
paulsmansfield's Avatar
paulsmansfield
I'm driving...
+1 on that. Why would you drive with only one hand on the wheel? you have much better control with both and just take one off to change gear and put it back.
Old May 24, 2006 | 06:30 AM
Fletch69z's Avatar
Fletch69z
As long as it's a manual it has it.
Old May 24, 2006 | 06:31 AM
DoomCue's Avatar
DoomCue
^ you're right.. must be korean..
You know, I would take offense at that, except I can spell peripheral and I'm Korean....
-djb
Old May 24, 2006 | 10:33 AM
3hree5ive0ero
Retired Admin
Wow, I know two good things about you now. Can spell 'peripheral' and Korean..
Old May 24, 2006 | 12:35 PM
ZBigDog's Avatar
ZBigDog
I cosign all of Kolia's takes. You can customize at what rpm you want the light to come on through the cars computer, just keep in mind what every1 said, that it blinks 500rpm earlier and then goes solid at your chosen rpm.
I set mine at high rpm's cuz its real damn annoying when you dont want it.
sherm
Apr 11, 2020 05:21 PM
sales@czp
Sep 23, 2019 03:30 PM
Depravity
Oct 1, 2015 04:49 PM
