Help. Did I **** up the 350z already!!
Originally Posted by Sailor
Don't want to be the bearer of bad news but same thing happened to me about two weeks ago then last week the clutch started slipping badly. The dealer says that the clutch and flywheel are shot and need to be replaced and they consider it normal wear and tear so it is not covered by warranty and will cost me $2000. Car has 14K on it and have complained to dealer and head office with no success so off to small claims court next.
Again we are dealing with limited info hear, and I don't understand why the RPM's were bouncing around, so maybe there is a deeper mechanical problem going on, but that should have anything to do with what he did.
In my case I was doing about 55 in 6th, dropped to 5th but clutch pedal stayed depressed and revs shot up to 6500 as I started to accelerate, car slowed right down hich was scary as I was trying to overtake someone at the time, that's when I noticed the burning smell. This all happened over just a few seconds, not like it was revving the engine for a long period. I have driven a stick shift for years and have never had a problem like this before. Saddest thing is the dealer actually had the nerve to tell me that if you drive the car like a sports car the clutch won't last.
In your situation, which may be the same as his, it was a mechanical problem(the clutch not fully engaging) which caused you to burn the clutch as you thought it was engaged and ready to accellerate. That sucks! Definitely doesn't sound like any fault of yours, but that's one of those things that will be tough to prove. Good luck!
Originally Posted by gsazabi
So you guys are saying blipping the throttle from 2k to 4k,
4k to 6k, etc. isn't good when you rev match?
Hmmm when I watch those guys driving in Tsukuba circuit
in Best Motoring International, they rev the rpm up almost to the
redline when they do hill-and-toe downshifting.
Like when they enter the corner on third around 4-5k,
they blip the throttle to nearly redline before dropping into 2nd gear.
I'm very confused
I'm very confused
In the Z, our manual lists top speeds for gears 1-3....
1 - 35mph
2 - 60mph
3 - 85mph
Revmatching is just matching the engine speed to your landspeed X the gear you're about to select. Whether you're upshifting or downshifting, it's relatively simple. You have to know how to revmatch before you worry about heel-toe downshifting. I think most people who heel-toe have a feel for when to downshift by the engine note. I don't pay much attention to my tach or speedo when heel-toe downshifting, I've got more important things to concentrate on.
Originally Posted by roast
I've seen one of those videos where the guy driving an NSX damaged his engine because he downshifted too early. It was near the end of the race and he was driving hard trying to catch the lead car. Unfortunately he was still going too fast for the gear he selected and you could hear the engine over-rev terribly.... then directly afterwards his car was no longer in a hurry and he starts complaining that "the stupid engine is overheating". It just goes to show that even the pros make mistakes.
1 - 35mph
2 - 60mph
3 - 85mph
1 - 35mph
2 - 60mph
3 - 85mph
Originally Posted by Z4Zoro
In my mustang I was able to rev up in 5th gear and drop it down to 4th. On the freeway I would be in 5th at 2rpm rev to about 3.5 and shift and had no problems.
Today in the Z I was in 5th gear going about 50mph at 2000 rpms. I reved up to about 4000 rpms and shifted in. The rpm gauge went left and right about 5 times. The clutch stayed in and released in a matter of seconds. After on the way home I had a weird smell. Did not smell like a clutch though. Not sure where it was coming from, I poped the hood and it smelt more electical than anything. Do you think I already ****ed the car up? Or is the smell growing pains?
Hopefully it settles over night.
So you were in 5th gear at a constant 2k rpms... and reved up to 4k in 5th gear right before downshifting? If i got this right, why would you wanna rev up to 4k then downshift???
Originally Posted by skaterbasist
Wait im confused. Let me see if i can get this straight.
top speed for each gear....
I guess there is a great possibility that the shift landed in 2nd. In 5th gear at 2000rpm shift to 2nd with a uprev would def. redline hard. Especially that close to top speed.
If you kept your foot on the throttle while engaging the clutch, then it wouldn't have been as noticeable.
My factory clutch got fried less than 3 weeks after I bought my new Z (less than 2000 miles brand new car). I let a friend drive it, I was with him. He was doing doughnuts(whipping cookies), something happened. Its like the throttle stuck, and it was bouncing off the rev limiter. Fkucnig stunk like clutch bad. Slipped like a btcih at high rpm. Had new nismo clutch & flywheel installed at 3000 miles… He is no longer certified to drive my car. (damn shame, he’s the type of driver that can squeeze every inch of power out of a car.)
I’ll let him drive my car on the track to see if he can beat my times.
Its important to know how much of your car is the car, and how much is you.
Here is another questions. Most clutches that burn out smell really bad for days and days. If I burnt out the clutch you would still smell it right? Because there is no more bad smell. The smell went away within 15 minutes or so after it happen.
Originally Posted by Miko
Is 5th@50mph really 2K rpms? I thought it'd be a little higher...
Well anyways, I think if you're at 2K rpm and in 5th, and you want to drop it in 4th, revving to 4K rpm might be a little to high...i'd figure for each gear downshift its like somewhere between 600-700RPMs. But even if you revved it to 4k and dropped the clutch, I doubt it'd really burn that much for you to be able to smell...maybe the clutch got stuck or something..who knows.
