Roadster problem
Old May 28, 2006 | 02:43 PM
bakmac's Avatar
bakmac
Exclamation Roadster problem
I have a 2004 roadster Z, and I was wondering if anyone knows how I can get rid of the hot air that leaks in through my vents while I have everything off and my vent is in fresh air and recycle. is the warm air coming in from the engine or is there anything I am doing wrong.
Old May 28, 2006 | 02:54 PM
Built2shredZ's Avatar
Built2shredZ
Make sure the Fan is to the off switch and not auto, there should be no air coming thru the vents if you have the system turned off.
Old May 28, 2006 | 02:58 PM
bakmac's Avatar
bakmac
I have everything off no fan it feels like the temp is on 90 and I have everything off and the fan on OFF position!
Old May 28, 2006 | 03:57 PM
CAN0802's Avatar
CAN0802
Turn your temp selector down to the lowest setting.
Old May 28, 2006 | 04:08 PM
CC 350Z's Avatar
CC 350Z
Also there are 2 settings for air flow. Use the re-circulated air setting not the fresh air setting. With the system off if the vent is open hot air will come into the car.
Old May 28, 2006 | 09:10 PM
ohw's Avatar
ohw
When you put air flow on re-circulate, A/C comes on with it whether you like it or not. And the air will be cool. I have not been able to use re-circulate without A/C. Anyone have the same issue?
Old May 29, 2006 | 04:04 AM
bakmac's Avatar
bakmac
I really appreciate everyone's input but, I have done everything you have suggested and still HOT air is coming through, could it be that the heater isn't being shut off internally? You can feel it creeping through the vents even at stand still.
Old May 29, 2006 | 04:32 AM
Netko350Z's Avatar
Netko350Z
Do what I do....close the vents!
Old May 29, 2006 | 07:34 AM
bakmac's Avatar
bakmac
thanks for not biting me netko350z
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
