Clutch Squeaks When Pressed
Old Jun 9, 2006 | 02:20 PM
drewRedlineZ's Avatar
drewRedlineZ
Default Clutch Squeaks When Pressed
Just took it to the dealer the said it was in the casing of the clutch and something needs to be lubed. NOT covered under warranty! F that! Good thing I bought the extended warranty for nothing! I understand the clutch isn't covered, but it's not like the clutch is going out or anything. My Z sounds like an old car when I hit the pedal only 26K miles. Annoying!!!
Old Jun 9, 2006 | 02:22 PM
Hotwire's Avatar
Hotwire
Take it to another dealer...
Old Jun 9, 2006 | 02:40 PM
hwood's Avatar
hwood
I have the same problem. It squeeks and crunches with only 30K miles. Tried WD40, no luck...Dealer said it was fine but remains annoying. I'm looking for suggestions too.
Old Jun 9, 2006 | 02:43 PM
VO...'s Avatar
VO...
Administrator
mine does it also. It doesn;t bother me though. I just turn the music up.
Old Jun 9, 2006 | 03:03 PM
hwood's Avatar
hwood
I can actually feel a "crunch" while pushing the peddal to the floor and lift it up. Happens about half way through. The noise is ok, the crunchy feeling is what I cannot deal with.
Old Jun 9, 2006 | 03:10 PM
alan00000's Avatar
alan00000
HAHAH LISTEN TO ME VERY CAREFULLY I Just fixed this problem on my z not to long ago THe creeking sound is completely GONE!!! I used WD 40. THe thing is you have to get down on your knees and if you look far enough you can see a spring WAAAYYY in the upper left hand corner behind the clutch pedal and spray right on the spring.
These pics will show you where to EXACTLY SPRAY!!! Do this and that annoying SQUUEEEEEEK is GONE BYE BYE CYA GONE!!!
http://img61.imageshack.us/img61/9088/picture0148am.jpg
http://img77.imageshack.us/img77/6043/picture0168kk.jpg
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
