how many chirps are actually possible?
Sorry but am I missing something here? What exactly is chirping? I understand that its when you shift and the wheels spin too fast or something of that sort. But I guess it has never happened to me or maybe I've just never noticed it. Could someone please explain it with a little more detail please?
Uh... 1st gear > gear change > chirp > 2nd gear > gear change > chirp > 3rd gear ...
If you understood what I said earlier, how do you not understand what a chirp means? Chirp is a sound that comes from your tires spinning faster all of a sudden than it was before.
simply said it's similar to peeling out but when you are upshifting... another thing is, you have to be quick on the clutch too... if you push and let off your clutch likea granny, then your not going to get the chirps, because the clutch is taking the momentum and making your engagement smoother...
just look at it like this... if your trying to burn out in first... do you slowly let out the clutch or do you rev up and dump it? that answer should explain all you need...
Originally Posted by roast
man ff3 eat your heart out I got 310's on the rear and get mad chirps 1st through 6th... i chirp every time I shift... it be mad tight yo...
at this entire thread.
at this entire thread.this thread--->
Also, if you have Base car you can dis weight the rear and get a chirp out of fourth almost every time. Be careful or you'll end up in a ditch though.
Tried to see if I could. Was kinda surprised. I need sticker tires now.
Originally Posted by highside107
What do you mean by "dis weight the rear" ?
Like I said, if you don't know what you are doing you'll find yourself in a ditch.
This can be done in long sweepers to the right as well but, even more risky if you don't know how to control a powerslide.
With your driving skills I'm not worried. With some of the yahoo's on here I would worry.
I, too, have 275s in the rear. I had P-Zeros and I chirped up to 4th.. Now I have Nittos, but I can't chirp into 4th as often as I could before. Funny because P-Zeros have better grip. I'm almost stock, btw.
. I used to be able to chirp 1-2 2-3 w/ quick shifting at 5k rpm w/ stock setup.
