Please HELP!!! ASAP
Old Oct 21, 2006 | 06:08 PM
DaytonaBlu350Z's Avatar
DaytonaBlu350Z
Question Please HELP!!! ASAP
About an hour ago my LED license plate bulb started flickering. I pulled it out, put it back in and both the lights went out. Also my taillights are not working when my lights are on ( the brake lights work) and the light around the radio went out. I checked all the fuses twice and they seem to be fine, its raining and its dark now so its hard to see very well. Please let me know what it could be or which fuse would it be. Thank you in advance
Old Oct 21, 2006 | 06:10 PM
superdude's Avatar
superdude
check under your hood for one of those bigger fuses, its near the battery.
Old Oct 21, 2006 | 06:12 PM
DaytonaBlu350Z
I checked all the little ones under there
Old Oct 21, 2006 | 06:21 PM
superdude's Avatar
superdude
and did u check with one of those circuit testers? if you check those bigger fuses that have 1-5 smaller fuses, if one goes bad, the whole thing goes bad.
Next thing to test is ground points and battery voltage. Do u have a voltmeter? If you do, it should run around 12 volts. If you dont, turn on your headlights and compare the level to normal level
Old Oct 21, 2006 | 06:52 PM
imjdoggie's Avatar
imjdoggie
Oh man good luck with that!! Someone help this guy.................
Old Oct 21, 2006 | 07:30 PM
DaytonaBlu350Z
Any other ideas, please
Old Oct 21, 2006 | 07:56 PM
MustGoFastR's Avatar
MustGoFastR
Did you pull out and re-insert the bulb when the lights were on? If so, that's what blew the fuse. I had this happen in my FX35. Took me forever to find the "hidden" fuse box that the culprit fuse was in. It was behind the battery (had to remove the plastic trim around the battery and windshield to get to it under a black cover. Not sure, but I figure the Z has a similar box located in that position...
Old Oct 21, 2006 | 08:42 PM
DaytonaBlu350Z
Yeah it happened as I was reinserting the bulb. I found two fuse boxes. one by the driver inside the car and one located by the battery.
Old Oct 22, 2006 | 05:41 AM
MustGoFastR
The one I'm referring to is a third box BEHIND the battery. Trim has to be removed to access it. Again, this was on my FX35, but essentially the same under the hood as the Z/G35, so check it out.
etkms
Jun 19, 2022 06:30 PM
LunchBox20
Oct 20, 2015 10:22 PM
