clutch length
Old Nov 1, 2006 | 03:25 PM
Fear's Track 06's Avatar
Fear's Track 06
Default clutch length
i just tried to lay a fatty burnout in front of my buddy's house and had a friend of mine in the car and some groceries in the back (mainly water and coke) and i reved up to about 5k and dumped the clutch in 2nd. usually the car spins its wheels just fine but nothing happend excepted the engine reving and the clutch completely slips. i only have 4500 miles on the car and it's bothering me because im scared that maybe me clutch is already gone. i was wondering what the aprox. life of the clutch on our car is when it is run pretty hard. and is it under warrenty? thanks for the input.
Old Nov 1, 2006 | 03:27 PM
Fear's Track 06
by the way my car reeks of clutch right now!
Old Nov 1, 2006 | 03:28 PM
HighwaySpeed's Avatar
HighwaySpeed
Question
Clutch abuse is not covered under the Nissan warranty. Are you over 18?
Old Nov 1, 2006 | 03:32 PM
thirty5ounces's Avatar
thirty5ounces
i wouldnt think your clutch would be slipping even when aggresivly driven after 4,500, either you have a defected clutch or you cant drive a stick, quit RIDING that clutch....thats what that smell is
Old Nov 1, 2006 | 03:37 PM
trentor's Avatar
trentor
if you're doing that very often, well, there's your answer. you've burned it up.
Old Nov 1, 2006 | 03:40 PM
DavesZ#3's Avatar
DavesZ#3
Next time try it in 1st gear instead of 2nd.
Fear's Track 06
dont do it that often but once in a while. i had a lot of weight in the back because of the soda and water. could that have been why my tires didn't spin, cause of all that weight.
Old Nov 1, 2006 | 03:41 PM
trentor's Avatar
trentor
^^yeah, i haven't tried it, but 2nd gear seems a little weird if you're stopped.
Old Nov 1, 2006 | 03:43 PM
Eazzy's Avatar
Eazzy
Jeez Dude ----Fock burn outs, Use first then slam 2nd. U done burned up ur clutch.
Old Nov 1, 2006 | 04:18 PM
bofa's Avatar
bofa
Did it feel like the clutch was stuck? Did the pedal come up? Others including myself have had issues with the clutch sticking in 06s when launching. Sometimes it happens andsometimes it didn't. I did a 2500 rpm launch in 1st and it stuck and burnt the **** out of the clutch. I did a couple more a day later and no problems at all... not sure that you can complain to the dealer that the clutch is sticking while doing 2500 rpm (or 5000 rpm in your case) launches...
Old Nov 1, 2006 | 04:23 PM
thirty5ounces
that 15 pounds of liquid in the trunk had NOTHING to do with it, your car isnt a manual turbo deisel you cant granny shift it.......next time start in first let clutch out slowly them dump and nail gas and slip your clutch foot over to the brake and slowly mess with the brake and gas,,,,keep it at a decent rpm....but i wouldnt recommend doing burnouts in this car.....
Old Nov 1, 2006 | 05:30 PM
jakesford's Avatar
jakesford
you can't do that with the VDC though... if you hit the brake it cuts throttle.
pull the fuse and your set. Once you get going in first, then power shift into 2nd, maybe on wet asphalt you could dump it in 2nd, but I wouldn't do it...
Old Nov 1, 2006 | 05:42 PM
Chad68's Avatar
Chad68
I have had my clutch stick maybe half a dozen times, with my 06.
The pedal fails to return to it's fully upright position sometimes.
I have noticed that it happens if I slip the clutch too slowly, while giving it lots of gas at the same time.
First time it happend was on the freeway and holy sheet it smelled like a%%.
Old Nov 1, 2006 | 06:02 PM
aren21's Avatar
aren21
Same here, sometimes it gets stuck, sometmies it doesnt. I dont do burn outs in it, I figure if the pedal gets stuck just taking off with some wheelspin, then a burnout would be bad. I think thats true what someone said about the Z not being a good car to smoke tires in. Even it was...tires are too expensive.
Old Nov 1, 2006 | 06:06 PM
bailey bill's Avatar
bailey bill
and i reved up to about 5k and dumped the clutch in 2nd. .
Why in the hell would you try to do a burnout in 2nd??
bill
Old Nov 1, 2006 | 06:31 PM
Fear's Track 06
^ because its smoother. n e way. yea. thinking back to it the clutch pedel did do something weird. n e way. i went back and burned out like crazy because it was bothering me. lol. but now im happy. went and drove around for a bit and fell in love with my z again. and then washed it, at night. haha. n e way, thanks for all the input. i dont know why i even posted it without testing it further. by the way i didnt have 15 pounds of liqued back there. i had like 130 pounds of liqued back there. i was coming back from Costco not Ralphs.
Old Nov 1, 2006 | 06:32 PM
Fear's Track 06
Thanks for everyones input!
Old Nov 1, 2006 | 06:38 PM
Eazzy's Avatar
Eazzy
Trust me ---A Ford F350 diesel can be started in Second with no harm---A 350Z can not. It will bite u. Ur just ruining ur clutch. If u want to start in second , Buy a Ceramic Button Clutch
Old Nov 1, 2006 | 07:52 PM
Chad68's Avatar
Chad68
When my 1997 Hardbody was new, I could sit in one spot and smoke the tires in second on dry pavement and that's a 150+/- HP 4 banger.
Now with 18's on it, I could probably do it but on wet pavement only.
Old Nov 1, 2006 | 07:53 PM
Fear's Track 06
its smoother in second when you jsut peel out but not brake stand. for brake stands you go in first.
