PSI blink and ICY?
Old Dec 19, 2006 | 09:12 AM
jeeper78's Avatar
jeeper78
Originally Posted by DaveZ06
DIAMOND BAR!! Hello neighbor it's been getting cold as hell down in our area so it's nothing to worry about. Just start up your car and let it warm up a bit before you head off and check your tire pressure when it gets warm to see if you lost a huge amount of pressure.
You're supposed to measure your tire pressure when they're cold.
CaliTouring's Avatar
CaliTouring
I saw ICY a few weeks back when I had went to Big Bear. I knew what it meant right off the back. And as far as tire pressure goes, all 4 tires should read 37 PSI for that is the PSI they should be at.
Old Dec 19, 2006 | 10:01 AM
HighwaySpeed's Avatar
HighwaySpeed
Exclamation
No, they are supposed to be 35psi when cold.
Old Dec 19, 2006 | 10:27 AM
CaliTouring
its hard to tell when its cold because the PSi changes when I drive. Its Weird, I never know my exact PSI for some reason.
Old Dec 19, 2006 | 10:52 AM
infamous350's Avatar
infamous350
Guys dont lie to him. Listen man take it to the dealer right away your car can explode at anytime or engine may seize rush to the dealers and and make sure u tell them about the icy light. And the psi light thats real bad it means power system inoperable it can be fatal to your long block dont bull**** him man its a known problem on 350z with 1500miles
lol
Old Dec 19, 2006 | 11:59 AM
jeeper78's Avatar
jeeper78
That's why you check before you start moving.
Old Dec 19, 2006 | 12:13 PM
xNeo's Avatar
xNeo
Mine stays "- -" until a little while after I start moving.
Old Dec 19, 2006 | 12:18 PM
z350boy's Avatar
z350boy
Originally Posted by sw0ng
what means its cold outside, ICY or PSI?
"ICY" means "ICY ..............psi MEANS Pounds per Suare Inch!!!! GOT IT!!!!!?????
Old Dec 19, 2006 | 12:56 PM
highside107's Avatar
highside107
ICY refers to outside temperature (comes on automatically when it gets to about 37 degrees or so; there is nothing wrong with your car). PSI is when your tire pressure gets low and it's warning you. My tires seem to lose air when it's really cold outside.
Old Dec 19, 2006 | 01:16 PM
usmanasif's Avatar
usmanasif
Because it knows you should have a good quality tire gauge to check pressure before driving off, when in doubt, and because the car needs to go above 15mph for the system to gauge tire pressure. TPMS is not 100% accurate; can be +/- 1-3 PSI at any given time depending on conditions.
Old Dec 19, 2006 | 01:18 PM
lilquazyvietboi's Avatar
lilquazyvietboi
ok, if u truly didnt figure those out by urself... EVEN w/o reading the manual... you are one dumb "beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeep"
Old Dec 19, 2006 | 01:33 PM
CaliTouring
Exactly!
Old Dec 19, 2006 | 04:44 PM
Reality350's Avatar
Reality350
Old Dec 19, 2006 | 05:29 PM
HighwaySpeed
Lightbulb
You check the tire pressure, when the car has not been used for a few hours or more.
Old Dec 19, 2006 | 06:09 PM
CaliTouring
ill keep that in mind
Old Dec 19, 2006 | 06:10 PM
Sometimes you frighten me. Tire pressure increases because you are driving, and driving causes heat. But don't be concerned. If the tire pressure is correct, then the tires will be fine.
Old Dec 19, 2006 | 06:15 PM
stein's Avatar
stein
One thing about when it displays ICY is it goes to the temp reading automatically. It a bit annoying since I leave it on the speedometer, and a few times I though I was going 31 when I was actually going >40 before I realized it.
Old Dec 19, 2006 | 10:35 PM
  #38
NISMO604's Avatar
NISMO604
today mine said
F
47
R
31
31
WTF
Old Dec 19, 2006 | 10:52 PM
  #39
CaliTouring
Originally Posted by NISMO604
today mine said
F
47
R
31
31
WTF
thats pretty fuked up LOL
Old Dec 19, 2006 | 10:57 PM
  #40
fairlady350z33's Avatar
fairlady350z33
Default im in the area sometime too
why thank you guys, got all the info i needs
and HELLO THERE DAVE, maybe we can meet up sometime, got a few questions about my car =D, btw what year do you have?
im from arcadia but i stay there quite a bit, I have a NISMO exhaust that i'm selling for my friend if u wana meet up and listen to it.
Ted
