How does z feel.
Originally Posted by Beka Z
hahah i do, but its still 60 degrees here. I'm freaking out reading the winter post... i have pilots on the front and i dunno on the back :-?>
Guys,im not against the z just want to be better than the prelude,i want to let the old prelude go,but it always stop me from getting a new sports car,because i don't to miss the feeling of the car.
Originally Posted by Rebellious350z
Guys,im not against the z just want to be better than the prelude,i want to let the old prelude go,but it always stop me from getting a new sports car,because i can't stop the feeling in it.
Originally Posted by zand02max
Then stay with the Lude, save your $ and get the GTR when it comes out!
not downing preludes in anyway here cuz i used to drive a honda myself... but its a completely different class of car. its def gonna be more exciting of a car and any lame a$$ can buy a honda an hook it up with ebay parts but you'll be rollin in a Z
Originally Posted by 350zz053
haha man stay with your Honda. The Z cant handle like a 30-40K two seater sports car. I mean its not like it has 300HP and 280tq. Or even RWD! It couldnt touch the honda!
GO TEST drive it and stop posting these gay threads. or you will learn soon you are a no one.
^which you should know by now in your prelude! lol
...But +1
Get the z i used to have a super charged ponitac it was real fast had it modded though i could never give it up one test drive on the z and i wanted to throw it in the garbage even though the mod potential on teh pontiac was so much better i never regret it when im doin a 125 and it feels liek 85 miles lol i love the z
Originally Posted by Bumpinjeep
Honestly? You get excited about a prelude? Seriously? Go and drive a Z. The difference between the two is like night and day. The Z is a fast car, much faster than any stock prelude. Its RWD so it handles better than any stock or modified prelude. It looks great, once again better than any prelude. And its a hell of a lot more fun to drive than a FWD 4 cyliner honda. Come on man, why not compare the lude to something in its class like a celica or a scion. Maybe you can get a better vibe from an eclips forum?
You should have taken a ride in my Prelude....
1994 Honda Prelude VTEC Turbo Parts list:
Motor Modifications:
JE Pistons 9.0:1
Eagle H-Beam 2 piece forged rods
JE Rings & Pins
Skunk2 (5 way adjustable) Cam Gears
ARP Head Studs
Darton Sleeves
Cometic Head Gasket PH coated (lowers compression to 8.6:1)
Center Force “Dual Friction” racing clutch
Misc. OEM parts from Honda:
Main Bearings
Rod Bearings
Oil Pan Gasket
Rear Seal
Front Seal
Cam Seals
Valve Cover Gasket
Spark plug seals
Oil Bearing seal
Valve Gaskets
Timing Belt
Adjuster
EGR Valve
Drivers Side Motor Mount
Front Side Motor Mount
Knock Sensor
VTEC Solenoid
Turbo Application:
Custom spec. DRAG Gen 4 turbo kit:
Turbonetics To4/T3 turbocharger w/ 57mm
Tial external Wastegate
Greddy Type-S blow off valve
2 1/4 in, 2 1/2 out chromed intercooler piping
Large Spearco front mount intercooler with polished cast aluminum end tanks
Cast iron 4into1 high flow turbo manifold with high temperature silver coating
2 1/2 inch mandrel downpipe w/ O2 sensor bung & high temperature black coating
High flow DRAG intake system with funnel ram filter
Steel braided Goodridge dash-8 oil feed line
Engine/Fuel Management: - Tuning by Ed @ Balanced Performance
HKS Type 1 Turbo Timer
HKS EVC III Boost Controller
Hondata Stage 2 w/ Boost.
P28 ECU
3 Bar map sensor
RC 550cc Fuel Injectors
NGK Iridium Spark Plugs
Walbro 255lph fuel pump
Misc. Parts
Short Shift Kit
High Flow Cat
Mugen Oil Cap
Motor x Boost Gauge
Autometer Air/Fuel
Axis Racing Ceramic/Kevlar brake pads atio gauge
For the OP, coming from a Prelude, I love my Z but there will always be something special about the Preulde. It has as much history as the Z does and the following that car has is something you could never shake a stick at. Good luck with your decison!
Hahaa, you former Prelude owners crack me up.
Yes, the Prelude was a nice car, and still is, but it is not in the same class as the Z.
Kind of like comparing my old FD to my old 4th gen VTEC.
One thing that should be noted. The prelude is a great car. I have owned quite a few hondas. The last one I owned was a 94 Hatchback Si. I must say, even though the Z is a stronger, faster, and better sports car than most honda cars....the civic FELT faster. Small, light car gave the illusion that it feels fast. So if you get in a Z and it feels a little sluggish, just remember your honda is lighter and the Z is a SOLID sports car....making speeds that would make the honda feel like its haulin a$$, actually feel like nothing.
I dont have a z yet, maybe soon,but driving my honda prelude always get me feeling excited, the car feel light,feel so cool driving it.I want to forget the prelude,.I know the z has more power and heavy,but will there be excitement to drive the hell out of it.Thanks
When i got in the Z, i coudlnt believe how tight the chasis is. Like when i press the gas theres no feeling of the rest of the car is being left behind. I was driveing a Honda Civic before.
Also the breaks man, wanna stop on a dime? you dont realize how crappy breaks are on a "normal" car until you get into a real one.
Honestly i feel its safer to drive the Z than a econo car. When i need to move fast or break fast the Z does it.
what the hell is this kid s@@@@@@? how can u compare a prelude to a z? its just impossible....i mean, u can! but whats there to compare when the answer is just the z is a way better car...i came from integra gsr to s2k then 350...id say s2k and z is comparable but integra, i dont know....its a nice car but different category!!!
