18's?
Depends on the width of the tire and the offset. On a 10'' tire, you can safely put 295 on there if it fits. Any more and the bead might come off. If you want more grip, which u look like u may need, u can always get a better grippier tire or get 0 camber.
Can't really help you much without the offset. A picture of the front and rear fenders can help to tell you how much room you have. If you have a lot of room, u can fit a bit more meat in the rear.
What tires do u use right now? If they're cheap ones, u can switch to Potenza S03s. They grip real nice.. They're the tires im getting next. Michelin PS2 are nice too
Most of the time, the offset is either engraved or is on a sticker on the inside rim of the wheel. The front and rear offsets may be different. If your wheels are flush with the fender, u cant really fit bigger tires.
have you tried the search. i know i read somewhere on here where they give you all kinds of wheel combos.
i know i read it but i don't understand anything about offsets and stuff. can anyone explain or maybe give me a link to read up on it. thanks
