Can I top off my resevoir with non-nissan coolant?
Old Apr 3, 2003 | 06:17 PM
Brad4rdHay's Avatar
Brad4rdHay
Default Can I top off my resevoir with non-nissan coolant?
Is it cool if I get the same blend type...or are they all basically the same. Whats the deal, Im running a little low on coolant but don't feel like driving all the way don to the dealership to get my coolant toped offed.
Old Apr 3, 2003 | 06:32 PM
ares's Avatar
ares
Veteran
I deleted your other post, hope you dont mind.
I dont see a problem with this tho, should be fine. better wait for a second opinion tho.
Old Apr 4, 2003 | 03:22 AM
bobbyz's Avatar
bobbyz
I dont think it would be ahuge problem if it was low from the beginning, but if you are loosing coolent, then you have a problem. It is a sealed unit, so the only way to loose it is if it is leaking somewhere.
Old Apr 4, 2003 | 08:09 AM
WayneTN's Avatar
WayneTN
The only guideline that I've heard is that some coolant/antifreeze is basically a 2-year version and some a 5-year version. Therefore, you should supplement with the same blend. (No, I don't know which the Z has.) Other than that, you should have no problem.
It's reasonable that the level could go down slightly over time - due to evaporation in the overflow tank if nothing else - but if it seems to go down more than "slightly", you could have a small leak somewhere and would need to get it checked out.
hth,
WayneTN
Old Apr 4, 2003 | 10:14 AM
can350z's Avatar
can350z
Default Another idea.........
Just pour in a bottle of redline water wetter or royal purple- purple ice.. Both products are good for temp reduction and mix perfectly with any oem system.. Used it in all my cars... both are highly recommended and work.......
Cheers......
Chris350z03
Oct 8, 2023 07:19 PM
350Z_Al
Oct 29, 2020 07:44 PM
Depravity
Oct 1, 2015 04:49 PM
SharX59
Sep 27, 2015 09:23 AM
