350Z Measurements/Dimensions Needed!
Hey all,
I am working on creating a 3d model of the 350z for my digital animation class. Does anyone know of any blueprints or schematic diagrams for the body? If I can get a nice set of measurements it will make my work a lot easier (and better, heh).
Also, is there anyone in the Phoenix area that wouldn't mind me measuring & photographic thier 350Z?
Thanks,
Jeff
Thanks,
Jeff
Jeff, I'd say you're best bet might be a Tamiya model and then you'll be able to take all the "scale" dimensions you need with a caliper and ruler... Plus, you can have a working model sitting right next to you as you go - so you can double check the appearance. From what I understand & have observed, the tamiya products are probably as close to accurate dimensions as you'll get - you'll just have to bump it up a few sizes once you go to the actual dimensions.
Good luck, lets see some graphics when you get done!
2003, 350z, body, diagram, dimensions, engine, exterior, intake, measurement, measurements, measurments, nissan, roof, top
