Downshift to engine brake in a 5AT...
Originally Posted by Z04
it is not needed on a 5AT, since when you are brakein got stop, the car shifts down for you anyway. now if you wanted to downshift like in curves or to make a pass for a quick burst of speed in the next lower gear, it should be fine to do that.
Originally Posted by davidv
I suppose that the
Should I downshift or should I brake?
conflict will go on forever.
Originally Posted by MeetJoeAsian
a lot of people say dowshifting in an auto "FEELS" like it wearing the engine, but does it really wear the engine if it's slowing the engine down? I don't care how it feels look seems like, but is it a fact that it wears the engine???
Are there any mechanics or someone who really knows FACTS instead of hearsay?
"...it puts little or no more load on your engine than it would otherwise bear, but saves considerable wear on your brakes"
bill
and that's the reason why I want to know some facts on the effect on the tranny...
I wasn't crazy about the 5AT in our cars. It didn't down or upshift when I wanted it to. It took about a second or two to downshift especially. The computer takes some of the control away. However, it is supposed to help take loads off of the automatic transmissions in these cars.
On a mountain road I'd rather have the stick.
In traffic the 5AT is much better.
Pick your tranny for the type of driving you do the most of.
I do not mine the stick in traffic. It gives me something to do. ;-)
I have a 90' 300zx MTrans
and a 2006 350z 5AT.
What I dont like about the AT is that when you step on it, the engine automatically downshifts, then gives you this almost uncontrolled amount of power, like you are being launched from a sling-shot, which can be dangerous if you are trying to pass someone and kind of over shoot the distance you are trying to go.
So to avoid this problem, if i need to step on it to make a pass on the freeway in a tight space, I slide over to the manuel mode, then downshift, giving me about 75% more control over what i am trying to do, it feels just like a regular stick shift when you do this, in terms of acceleration control.
(pointless post I know, Im sure everyone with 5AT does this, just thought Id share anyways)
I dislike the question (posted about once each moth) because it offers false choices: downshift or brake. Neither is a correct answer. A good driver uses the transmission, brakes, clutch and accelerator together to control the car.
I use a lot of engine braking on my sportbikes, and trust me when you're on a motorcycle, engine braking vs conventional braking can mean a difference between crashing or stopping in certain situation...
I'm gonna see if I can find more reliable sources of pros and cons on this topic...
actually, I haven't seen many threads concerning this issue...and any thread that's related or comes come to relating to this issue have mostly been hearsay, or what everyone THINKS should be done...bailey bill found that really interesting article regarding this subject...
Two racers at the track. One hits the brakes hard, spins the tires coming out of corners, ands hits the throttle hard. The other does everything smooth. All transitions from slow to acceleration, and acceleration to slow are seamless. Both have the same lap times. Neither technique is better. Both get the job done.
Originally Posted by crskillz
...I too am curious about the harm it does to the engine (if any)....
Posting for the 3rd time:
Why would you think using the engine to DEcellerate would cause any more wer than using to ACcellerate.
When you lift, whether you downshift or not, the engine is coasting.
bill
Originally Posted by spf4000
Didn't the automatics come with rev matching since the 05 model, where the car automatically bumps up the engine speed when you downshift? If so, there shouldn't be that much additional stress to the drivetrain. I'm not a big fan of using the engine to slow the car down to save the brakes.
(to many to count)........
Originally Posted by ROSELL0522
Not one person commented about the rev matching after it was brought up?? I thought that was the purpose of the rev matching also to help with the strain you might get shifting down with the manumatic. Any one else think that or just two z owners out of ******* z owners
If you're racing or driving sprinted while using the manual mode on the 5AT then both the engine & tranny are taking a hit to their longevity. If you're driving it normally and down shifting to delay using the brakes, and up shifting to better manage the gear your in then I don't think you causing any more wear but may want to change the fluid more often.
IMO, use the brakes unless your going down hill or a similar situation.
I have an 06 5AT and it appears to rev match to within +/- 200 RPMs.
I think you are talking about style more than proper technique.
Originally Posted by JonsilvZ
Just use the damn brakes! Pads are cheap and you save fuel from just braking.
Engine braking when done right ftw. I have 82,000 on my SS Silverado now with the stock brakes and pads and there is still 1/2 the pad left. This is the 1st auto I'v done it with but I'v had no problems. (and thats the longest lasting brakes I'v ever had :O)
You use more fuel when engine braking because of the higher rpms.
No. When coasting to a stop fuel is keeping the motor running. When engine braking momentum is doing most of the work.
