What's the best way to shift smoothly?
Old Apr 22, 2003 | 09:50 AM
ZeeForMee's Avatar
ZeeForMee
Default What's the best way to shift smoothly?
say if you were just cruising? After you depress the clutch, do you keep the motor revved to proper speed, then put it in gear and let the clutch out? What's your technique?
Old Apr 22, 2003 | 10:10 AM
christoc's Avatar
christoc
I blip the throttle to rev match then slowly let the clutch out to let it grab and bring the motor to it's proper speed.....
Old Apr 22, 2003 | 11:43 AM
Ricky's Avatar
Ricky
Yeah same thing.. here's an example..
I'm at about 15mph, in 1st, I shift to second, while depressing the clutch, gently press the throttle to about 1,500rpm and release clutch, it kills the chops between shifts.. takes some getting used to, but it helps, but if you press the gas too much and release clutch, you get a little bounce
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
Ace2347
Sep 22, 2015 03:12 AM
