How can you visually tell the difference between the base and Enthusiast models?
Old May 5, 2007 | 01:46 AM
Un-Kut's Avatar
Un-Kut
Default How can you visually tell the difference between the base and Enthusiast models?
can you spot the LSD component? is teh stalk for the cruise control different?
Old May 5, 2007 | 01:52 AM
Not unless you disassemble the rear axle.
Old May 5, 2007 | 01:53 AM
JDMFairladyZ33's Avatar
JDMFairladyZ33
For 03-05 The base had no power rear view mirrors, no aluminum pedals, no cruise control, HIDs, TCS, and no TPMS.
Old May 5, 2007 | 02:03 AM
zpak's Avatar
zpak
The deeper question is: why do you care?
Are you debating between a Base and an Enhusiast because of...(what?) Function often outweighs cosmetic appearance (and it SHOULD).
That being said, if you're going to modify your vehicle anyway, does it matter? Many Z's are morphed to such a degree, you can't identify it from its factory "appearance", regardless of trim.
Old May 5, 2007 | 02:12 AM
Un-Kut's Avatar
Un-Kut
not because of appearance, because of assurance that you got what you pay for
Old May 5, 2007 | 02:36 AM
calin's Avatar
calin
huh? well i dont know but if it goes from 0-60 in 2.6 seconds, its an RSX
Old May 5, 2007 | 02:42 AM
Z04's Avatar
Z04
wow, this has to be the dumbest n00b question yet. you can not visually tell the difference between the Z models since you can pretty much order what you want on the car from the dealer anyway.
Old May 5, 2007 | 02:58 AM
zpak's Avatar
zpak
Assuming no mods were made in the interim, the diff b/t a base and an enthusiast are:
1) Cross-drilled aluminum pedals on the Enthusiast
2) Steering wheel-mounted controls for cruise control/audio controls on the Enthusiast
But, really, honestly, you didn't have to come to this site for this info. All this is available at:
www.nissanusa.com
That's where I looked for about 11-12 months (memorizing the stats of each trim) before I bought my Z. They even have a dealer-locator function that can locate the exact Z you want (with the exact specs) within a reasonable radius of travel to your home.
You should really check it out...I mean...at some point in time...
Old May 5, 2007 | 02:59 AM
Lusky's Avatar
Lusky
my base has HID's and TPMS
Old May 5, 2007 | 03:02 AM
JDMFairladyZ33
Then you dont have a base if it's a 03-05 You don't even know what kind of Z you bought.
Here's a little help man
http://www.nissanhelp.com/Models/200...ifications.htm
Edit: I just read your other post. It's not that you don't know what Z you have it's you CANT read. ^. You have an 06. It's completely different in the packaging.
I have my 2006 350Z on autotrader. The car has under 13K miles, $29K window sticker. I have it listed for $22,500. The car is only 5 months old. I hope it sells.
Old May 5, 2007 | 08:15 AM
The Brickyard Rat's Avatar
The Brickyard Rat
This is easy: Look at steering wheel; if it has cruise control buttons it is at least an Enthusiast. If no buttons, its a Base.
Old May 5, 2007 | 08:16 AM
NYPZ's Avatar
NYPZ
hmmm i bought a nissan, its got two doors and its pretty quick. It has i think like a zorro emblem on it.....wow
Old May 5, 2007 | 08:31 AM
CG350z's Avatar
CG350z
Old May 6, 2007 | 01:30 AM
Z_Driver's Avatar
Z_Driver
Master
My Base has power rear view mirrors and it's a 04. I thought all Z's had power rear view mirrors. ????? WTF ?????
Old May 6, 2007 | 01:39 AM
JDMFairladyZ33
04 base models do not have power mirrors. Either you do not have a base or somebody added that feature in.
Old May 6, 2007 | 06:47 AM
Velocity350Z's Avatar
Velocity350Z
Search!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old May 6, 2007 | 06:57 AM
streetracer's Avatar
streetracer
I have an 03 base with NOTHING, not even vanity mirrors, and the side mirrors are electrically adjustable.
Old May 6, 2007 | 09:42 AM
SouiT's Avatar
SouiT
Must be an RSX
Old May 6, 2007 | 09:46 AM
jjwalker's Avatar
jjwalker
06 Base and up get Bi-xenon lighting and TPMS.
Old May 6, 2007 | 10:37 AM
Cannysage's Avatar
Cannysage
xenon
