HUGE DEBATE! Coast in NEUTRAL
Old Jul 14, 2007 | 09:02 PM
  #81
HDPDZO6's Avatar
HDPDZO6
Originally Posted by gsazabi
Only time my car's in neutral is when it's stuck in traffic/stop light
Switching to neutral at stoplights was a hard habit for me to learn. So used to keeping in gear from my days of truck driving.
Old Jul 15, 2007 | 09:58 AM
  #82
flintgauge's Avatar
flintgauge
Old Jul 15, 2007 | 11:35 AM
  #83
roast's Avatar
roast
Originally Posted by flintgauge
Cmon, don't retract. Argue with the service manual. I know you wanna..
Old Aug 5, 2007 | 07:43 PM
  #84
derekinthez's Avatar
derekinthez
Default Brakes
Originally Posted by I1DER
I look at it as any time I'm moving and in neutral, I have less control over the car. It may save gas, but so will wind slipping behind a Greyhound bus. If the bus brakes you're screwed. If you need engine braking or power when in neutral you're screwed.
How are you screwed? If you know you are coasting and you see a bus in front of you, one with common sense would apply brakes sufficient enough to stop prior to hitting the bus. Coasting at 750rpm (idle) will always save you more gas than engine braking, IMO.
Old Aug 5, 2007 | 07:58 PM
  #85
roast's Avatar
roast
What if hitting the brakes is not what the situation calls for? What if you have to yank the steering wheel instead of hitting the brakes? It's much easier to lose control over a car in neutral than a car in gear. It's pretty common knowledge to anyone who has any high performance driving ability.
As for saving fuel, read the thread. You are wrong.
Old Aug 5, 2007 | 08:17 PM
  #86
Miko's Avatar
Miko
I was in gear at 2500 RPM and turned the car off...same noise as if it was on. Then, you just turn the key to ACC (not to actually *turn* it on as if it were parked in a garage..) and you notice no difference what so ever turning it on. I guess that proves the no gas consumption while coasting in gear..
etkms
Jun 19, 2022 06:30 PM
ablaine
Nov 29, 2016 10:13 AM
AbyteZero
Sep 22, 2015 09:17 AM
