Z in the SNOW/WINTER???
Old Sep 14, 2007 | 09:21 AM
dzine07's Avatar
dzine07
Question Z in the SNOW/WINTER???
I'm looking at getting a g35 or Z and im really concerned about how this car might perform(or not perform) in the winter months. Anyone have any experiences? advice? i know i need a good set of tires and trac control. is that enough?? I live in Duluth, Minnesota -if anyones ever been here or know of the place drop me a line. Some people tell i shouldn't look into a car like that and others comment that years ago they drove RWD cars without trac and ABS -you just need to know how to drive in the snow.
Thanks guys! anything will be helpful.
Old Sep 14, 2007 | 09:23 AM
Spork's Avatar
Spork
You really just need to know how to drive in the snow. And if you plan on driving in the winter, don't get the base model, as that doesn't have an LSD. If I were you, I'd spend an extra $2000 and get a winter car. I've got a grand am to use for the winter.
Old Sep 14, 2007 | 09:24 AM
Z04's Avatar
Z04
please search since this is has been discussed numerous times since the forum has been around
Old Sep 14, 2007 | 09:30 AM
VQZ33_Jake's Avatar
VQZ33_Jake
I wouldnt take the risk.
Old Sep 14, 2007 | 09:34 AM
If you need a year-round vehicle in a snow belt state, there are better choices than the 350Z.
Old Sep 14, 2007 | 09:40 AM
Jenn350Z's Avatar
Jenn350Z
It's horrible in the snow
/thread
Old Sep 14, 2007 | 09:42 AM
fishlo's Avatar
fishlo
I live in NJ and drove my car numerous times in the snow. I have a base with no traction, so you really gotta know how to control the car.
Last month I almost lost control of the Z driving on a curvy highway ramp hours after it rained, because the road was still wet.
However I also have a kia that I drive when the weather is really crazy.
The choice is yours!
Old Sep 14, 2007 | 10:04 AM
KManZ's Avatar
KManZ
Well, if you use the Mountainous/All-Terrain Mode on the Z, you should be ok. The button is next to the seat heater buttons, you know, that one button.
Old Sep 14, 2007 | 10:05 AM
DumbGenius's Avatar
DumbGenius
From: Calgary, Alberta, Canada, Earth, Solar System
Good car in snow if you have good snow tires up to a couple inches of snow. Don't try it if your tire is OEM.
Old Sep 14, 2007 | 10:17 AM
SargentZ's Avatar
SargentZ
get some blizzaks and you should be alright. Search Search Search as this topic has been beaten to death!
Old Sep 14, 2007 | 10:49 AM
I1DER's Avatar
I1DER
It is incredible, even without the optional snow blower attachment. The front is low enough and rounded enough to plow most snow away before it gets under the tires.
JK. Search the threads, you'll be snowed with the information. I would pay attention to where the voices of opinions are from. The many from SoCal and Florida, just perhaps, will not have the same insight as those from Winnipeg and Toronto. I'd check your regional sub-forum first. I'm sure there are those that daily drive them all year round.
Old Sep 14, 2007 | 12:43 PM
Firebase99's Avatar
Firebase99
ROTFL!!!
Old Sep 14, 2007 | 12:50 PM
Dio1988's Avatar
Dio1988
there's a million discussions on this. just go to search and type in snow
Old Sep 14, 2007 | 12:56 PM
Spork's Avatar
Spork
I thought that button was for Invisibility Stealth Mode???
Old Sep 14, 2007 | 01:01 PM
sry110's Avatar
sry110
I'll contribute again, since the thread has already been opened.
My personal story: I have an enthusiast model, which includes Traction Control System and OEM limited slip differential, as well as manual transmission. I live in southeastern Pennsylvania. Last winter I used a set of Bridgestone Blizzak LM-22 tires, sizes 225/50/17 front and 235/50/17 rear. We did not get much snow last winter but we got a few storms. I was able to get where I needed to go even with an inch or two of snow on the ground. Hills and sloped roads were challenging but not impossible. I did not need to load the hatch with sand bags to achieve traction. Slow, patient driving gets you where you need to go. If the level of snow on the road exceeds a few inches you should not be driving this car anyway. If you absolutely must drive in that kind of condition (i.e. a blizzard starts while you are at work) then I suggest buying a second vehicle that can handle it, and just keep your eye on the weather so you know which car to take.
I plan to use my winter wheel/tire setup again this year instead of buying a second vehicle. Another vehicle means committing another large chunk of money (purchase price, oil changes, inspections, insurance, etc.). Wheels and tires are much cheaper to own than an entire vehicle.
Good luck with your decision.
Old Sep 14, 2007 | 01:20 PM
timgiwo's Avatar
timgiwo
Default Go for it
I say just get the car. I'm in Minnesota with you and this one will be my first winter as well! After scouring these forums for advice on whether I should by I just came to the conclusion I'm pretty sure it'll be fine. I'm not sure about Duluth but I know at least around the Twin Cities area, they're really good about plowing and keeping the major roads clear. If your surrounding area is mostly street parking (like uptown) you might have a problem with snow depth and big chunks of ice. Those streets are generally not swept as often as others.
I mean, think of all the ppl that drive Beamers around here. Those are rear wheel! Just get yourself some good winter tires like me and we'll be fine!
Old Sep 14, 2007 | 01:37 PM
HitLines's Avatar
HitLines
These are much better in the snow:
Please try a search as this has been covered every year.
Old Sep 14, 2007 | 01:50 PM
SniperHunter's Avatar
SniperHunter
Snow shoes. And drive very cautiously.
You'll be fine.
Old Sep 14, 2007 | 03:10 PM
Bockrocker's Avatar
Bockrocker
I have the 05 Enthusiast model with Toyo Garit KX tires on oem 17s. Z is a DD up in Mass. Get a good set of winter tires and you will be fine. Do not attempt driving on stock tires! They are worthless on ice and next to it on snow. A good set of winters will get you from A to B faster/safer than most on the road even in heavy blizzard conditions. If the snow piles up too high, you can always plow your driveway with the car…
Old Sep 14, 2007 | 03:42 PM
FastZ33's Avatar
FastZ33
do not mix
