Oil change on lowered 350z with lip kit....
Old Oct 4, 2007 | 10:32 PM
litlechina's Avatar
litlechina
Default Oil change on lowered 350z with lip kit....
for those of you who change your own oil...how do you jack your car up? I cant get a jack under my car at all.
thanks
Old Oct 4, 2007 | 10:38 PM
FAIRL4DYZ's Avatar
FAIRL4DYZ
make a homemade ramp or just by some 2x4 so you can drive on them so the car will be a bit higher from the ground so you can get a jack under there.
Old Oct 4, 2007 | 10:40 PM
litlechina's Avatar
litlechina
i see... thanks haha
Old Oct 4, 2007 | 10:43 PM
RedLine 350z's Avatar
RedLine 350z
I used the stock jack to lift it high enough to slide my floor jack for faster lifting.
Old Oct 5, 2007 | 12:05 AM
blktrack350's Avatar
blktrack350
get a jack made for lowered cars. mine is like 3.5 inches off the ground. and that will get under the side of mostly any car. and it still lifts 17 inches off the ground
Old Oct 5, 2007 | 12:29 AM
05Redline's Avatar
05Redline
I place bricks under the front of both front tires then drive up onto them so i can slide the floor jack under the car.
Old Oct 5, 2007 | 12:34 AM
Z_Driver's Avatar
Z_Driver
Master
I just drive up on my ramps. The ramps have extra extensions made out of two interlocking plastic pieces to make the transistion easier.
The other thing you can do is drive up on a curb at the driveway... That gets about 11 inches.
JjL
East Canada
Jun 12, 2019 03:04 AM
James1990
Dec 16, 2015 08:57 PM
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
bcoffee20
Nov 19, 2015 06:39 PM
rizzla
Drag
Sep 17, 2015 08:44 AM
