Bottoming out HARD, can it hurt the car badly?
Old Jan 15, 2008 | 01:32 PM
soshiv's Avatar
soshiv
Default Bottoming out HARD, can it hurt the car badly?
I just bottomed out HARD, was coming up a slight incline at about 10-12mph... and BAM dead stopped... it was a slightly raised manhole.. what exactly could i mess up besides the oil pan or exhaust??
Old Jan 15, 2008 | 01:34 PM
Risky_Business's Avatar
Risky_Business
Quadrant 987c
Lightbulb In...
reference to your title...it doesn't help.
pHiLDeZnUtZz's Avatar
pHiLDeZnUtZz
your best best is to take a look under the car first. if you start to notice some problems then take it to a shop.
Old Jan 15, 2008 | 01:43 PM
3,000 pounds of steel landing on any part of the undercarriage can be damaging. Only way to know is put it on a lift.
Old Jan 15, 2008 | 01:57 PM
350ZYALATA's Avatar
350ZYALATA
Tentill4z
+1 on everything
If you start noticing problems take it in and see what you might have messed up. Check your oil pan for leaks.
Old Jan 15, 2008 | 02:10 PM
soshiv's Avatar
soshiv
its been parked for about an hour and no fluid signs underneath so thats a good sign, exhaust sounds normal and it still drives straight... seems like im ok i guess... you cant mess up your transmission like that can you?
Old Jan 15, 2008 | 02:30 PM
mega_boi's Avatar
mega_boi
probably not with what happened to you. but it is possible if you bottom out REALLY REALLY hard, then yes.
but if you bottom out that hard, you have more to worry about than just the trans. maybe some chassis bends or mis alignment of all the suspension bits.
i doubt it was THAT hard though.
Old Jan 15, 2008 | 02:40 PM
soshiv's Avatar
soshiv
I tell you what, my heart sure did stop for a second lol
Old Jan 15, 2008 | 04:05 PM
350ZTheStandard's Avatar
350ZTheStandard
I had the same problem & now the radio only plays country muZik....
Old Jan 15, 2008 | 09:28 PM
Escobar's Avatar
Escobar
hahaha, you should be fine. If anything it could have messed up your alignment, but apparently not.
Old Jan 16, 2008 | 03:34 AM
KManZ's Avatar
KManZ
Time to knock the bottom out of her again...
Old Jan 16, 2008 | 06:29 AM
DraGonAlchemist's Avatar
DraGonAlchemist
it probably hit the exhaust. .in my shop i have a older middle ground style lift. .and i was going slow as hell over it and it just caught my tp/h pipe connections and car wasn't going any further. .my thing is. .Be More Careful when Driving. .I swerve everything. .except for deer!!! haha
Old Jan 16, 2008 | 08:35 AM
finalforce's Avatar
finalforce
At that speed I don't see any major damage. You mentioned you didn't see any fluids leaking or a change in sound/idle so that's a good sign for you.
Old Jan 16, 2008 | 08:36 AM
WhiteNoiz's Avatar
WhiteNoiz
Lift it, check the exhaust, oil pan, tranny, and diff. Then take her for a drive an test the allignment. Thats what I would do for peace of mind. If you notice anything otherwise, like others have said, take it in. Luckily you were going fairly slow.
Old Jan 16, 2008 | 09:18 AM
VO...'s Avatar
VO...
Administrator
It's a pretty tough chasis. I ran over a 3 foot wide median and the car handled it like a champ....
Old Jan 16, 2008 | 09:27 AM
WhiteNoiz's Avatar
WhiteNoiz
done that before, different car though, no damage. I also skipped over a car battery on the freeway, no damage, but it did leave a streak of red from the battery plastic. I had to chase the truck driver down...he was only concerned about his battery. I was like WTF!? I could have died if I didnt straddle it!
Old Jan 16, 2008 | 11:29 AM
VO...'s Avatar
VO...
Administrator
Old Jan 16, 2008 | 12:17 PM
abui01's Avatar
abui01
I bottom out everyday over the speed-bumps going to work. You shouldn't worry about it if nothing is leaking.
Old Jan 16, 2008 | 12:28 PM
WYZIWYG's Avatar
WYZIWYG
Stop driving your car like this then....
http://www.seriouswheels.com/pics-19...-1600x1200.jpg
Old Jan 16, 2008 | 06:41 PM
SiNzz's Avatar
SiNzz
Yup, been there done that too in a similar situation. Thankgod I was going extremely slow and had no damage apart from an apparently bent exhaust hanger that will be replaced with my new exhaust. Just check for leaks, alignment problems or anything else out of the ordinary.
