W A R R A N T Y
Old Feb 8, 2008 | 10:32 AM
Bumble_Zee's Avatar
Bumble_Zee
FREEDOM FIGHTER
Originally Posted by DraGonAlchemist
jesus 5 hours? did they start the work and it took them 5 hours. .or was it that long to do the work and even get it inside too start the work?. .took me like 30 minutes and i did both sides myself. .i took my car one time only for the alignment issue (tire feathering) and they had to look at the car, probably drove it around for fun, then when i picked it up 1/2 a day later they said i had to come back because they ordered my tires, and they had to confirm it was the recall. .i was beside myself. .then finally a few days later i took the car over and it took them more then 1/2 the day to put on 2 damn tires, and they didnt have to align it i told them due to the fact that i own my own hunter alignment machine. .to top it all off few hours b4 i picked it up they called me at work telling me that at 20K i needed certain tune up parts. .thieves. .Imagine how many poor souls they get with that one. .specially some women/illegals who know nothing about the cars. .
they keep sending me the fuel line above my gas tank recall, and i refuse to go. .if or when i smell gas then i may consider it. .otherwise i'll BUY the part myself and do it myself. .im not letting them remove my borla, and stillen sway kit/gtspec bars to drop my gas tank. .F that ****. .other then axle click/window smear/tire issue. .my Z's running and now working beautifully. .
when you say "TIRE FEATHERING" that means it is not properly alligned? do you know if the 2005 Z are on recall for this? man, I swear I hate DEALERSHIP *****
Old Feb 8, 2008 | 10:58 AM
DraGonAlchemist's Avatar
DraGonAlchemist
im not too sure on an 05 if that was an issue. .but it was on the 03's. . ..truthfully i never looked into it if they fixed this issue. .but so far on my alignments that i do the computer still tells me that there is no front camber/caster adjustment on the Z. . .unless they make a kit in which i think they do.
Old Feb 8, 2008 | 11:42 AM
CRJ700's Avatar
CRJ700
I just took my 05 ZR in to the dealership (DD auto group) for a roaring noise on RF side. Ended up replacing both front tires + alignment due to inside wear and "cupping" . I researched the issue and couldn't find any thing about a recall on 05's, just 03s and 04s.. Trust me, I'd love to have the $550 back. It kind of cheesed me off becaused I had not abused this car but ended up replacing tires that had plenty of miles left on them due to a problem that did not manifest its self until it was too late.
I hope this is not a recurring problem. I purchased the car used("certified" by the dealership). I can't justify that kind of money to the "boss" every 9 months.
Old Feb 8, 2008 | 11:57 AM
DraGonAlchemist
some z's after i do them do not require a camber/caster adjustment. BUT even if they did stock does not allow you to adjust them. Just Toe. . .i suggest after doing the tire replacement or even b4 you take it for an alignment other then the dealer. .and see if your car requires a camber/caster adjustment. .then if they make a front kit buy it so as not to ruin tires every5-10 k/ /.
Old Mar 2, 2008 | 10:50 AM
zstreet86's Avatar
zstreet86
all the dealers here in El Paso SUCK!!! i would never take my car to the local dealer here
Old Mar 3, 2008 | 06:38 AM
Bumble_Zee's Avatar
Bumble_Zee
FREEDOM FIGHTER
:word: there's only two, and they both won't help you out if they can't make money outta you... some presedential customer service for 7 straight years eh?
Old Mar 4, 2008 | 03:01 PM
zstreet86's Avatar
zstreet86
right-o
