Dude offer me 60g’s for “Z”
Originally Posted by doug
I called you out.. and i still am about some of those numbers.. they seem a little too high.. i think you are embelishing some of those mod prices you paid for..
i will list my call outs
1) you said you paid 17k for your first setup.. which was APS TT on stock block.. at most that should be 14k with ALL the bells and whistles
2) you said you paid 37k for your stage 2.. a 4.2L block from GTM with sleeves is 18k .. you are missing alot in that
3) you said you paid 6k for your audio equipment.. at best that stuff is 3k.. but you said you went to an overpriced shop notorious for ripping off celebs.. but unless you got custom fiberglass everywhere.. your numbers are still off
personally i believe you made a claim of 80k and you are trying to stand by it by monkeying up the numbers.. but hey.. you do wat you got to
At z1
Parts $ Labor $
APS twin turbo kit $7,950.00 $2,500.00
colder stage NGK plugs $60.00
Metal Turbo to manifold gaskets and turbo to testpipes gaskets $60.00
3.5" test pipes $345.00
3" cat back exhaust $1,575.00
Z1 upgraded clutch and flywheel $799.00 $100.00
Kinetix SSV extreme flow manifold $819.00
Blitz SBC color center consule $789.00 $175.00
Blitz turbo timmer $99.00 $175.00
Methonal Injection $550.00 $600.00
AMS performance radiator (thick) $425.00 $85.00
KJR light weight harmonic balancer $175.00 $60.00
Hotchkis sway bars $324.00 $100.00
2 good used O2 sensors $100.00
$500 discount for paying with cashiers check / money order -$500.00
customer wants every thing to look stock untill he opens it up
Sorry, but we do not accept personal checks SubTotal $17,365.00
Payment Method Tax $949.90
Shipping
Total $18,314.90
At forged
Item Description Ordered Rate Amount
ATS ACN 23380-... Carbonetics 350Z/G35 Triple Disc Carbon Clutch
1350kg Pressure Plate
1 2,583.00 2,583.00T
HKS 1402-RA002 HKS 1000cc Low Impedence Injector 6 180.00 1,080.00T
HKS-42012-AK001 HKS FCON VPro 1 1,395.00 1,395.00T
HKS-42002-AN005 HKS FCON VPro Harness for 350Z 1 495.00 495.00T
HKS-4299-RA008 HKS Pressure Sensor Super Wide Range 1 225.00 225.00T
HKS-4603-RA001 HKS Air Intake Sensor 1 65.00 65.00T
HKS-4299-RA016 HKS Intake Air Temp/Pressure Sensor Harness 1 40.00 40.00T
HKS-91112-086100 HKS Intake Air Temp. Sensor Mount 1/8 PT 1 16.00 16.00T
HKS-44006-AK002 HKS A/F Knock Amp 1 890.00 890.00T
HKS SNSR-0101... HKS Knock Amp NTK Wideband Sensor with HKS
Connector
1 390.00 390.00T
Labor-Mech Labor: FCON and Knock Amp wiring installation with
sensors
4 100.00 400.00
JWT A3505-REVS7 JWT VQ35 S7 Camshaft Set for Rev Up Engine 1 1,150.00 1,150.00T
JWT-VQ35-Sprg JWT VQ35 Spring/Shim Kit VQ35 1 225.00 225.00T
Labor-Mech Labor: Dissassemble/Reassemble Heads change springs,
lap valves, and set valve lash
4.5 100.00 450.00
Misc Resurface Cylinder heads 2 95.00 190.00T
Arias-Extre-9.0 Arias Zero Silicon AL EXTREME Duty Piston set 9.0:1
.020 overbore
1 1,000.00 1,000.00T
Egl-Rod-VQ Eagle Forged H Beam Beam Rod set VQ35 w/ ARP rod
bolts
1 500.00 500.00T
ARP-VQ35-Mains ARP VQ35 Main Stud Kit 1 200.00 200.00T
Cos-PR7910 Nissan VQ35 (3.5L) Rod Bearing Set-Tri Metal: STD 1 107.00 107.00T
Cos-PR7911 Nissan VQ35 (3.5L) Main Bearing Set-Tri Metal: STD 1 100.00 100.00T
Cos-PR7859 Cosworth Thrust Bearings STD 1 20.00 20.00T
NIS 15010-AC700 Nissan OEM Rev-Up Oil Pump 1 204.00 204.00T
Misc Forged Performance Shortblock Machining, blueprint,
and assembly
1 1,600.00 1,600.00T
HKS-23001-AN002 HKS Metal Head Gasket 97mm 1 320.00 320.00T
ARP-L19-VQ35-HS ARP Extreme Duty Head Stud Kit L19 1 400.00 400.00T
Labor-Mech Labor: Engine R/R Breakdown Reassembly 25 100.00 2,500.00
Labor-Mech Labor: Turbo Kit R/R 8 100.00 800.00
NGK-350Z NGK One Step Colder Spark Plug 350Z/G35 6 10.00 60.00T
NIS 10101-AC329 Nissan VQ35 350Z/G35 Engine Overhaul Gasket Kit 1 240.00 240.00T
NIS 12296-31U20 Nissan VQ35 350Z/G35 Rear Main Seal Retainer
Assembly
1 50.00 50.00T
GRE 13901000 Greddy Type-S High Pressure Radiator Cap 1 23.75 23.75T
NIS 15208-65F00 Nissan VQ35 OEM Oil Filter 2 10.00 20.00T
Misc Napa Break In Oil 12 2.50 30.00T
Misc Coolant 1 12.00 12.00T
Misc Power Steering Fluid 1 9.00 9.00T
Labor-Tune FCON Calibration and Complete Tuning 1 500.00 500.00
Misc 20'' electrical wire 20 0.70 14.00T
Misc 50' Heat Wrap 50 2.00 100.00T
Misc Silicon Vaccum lines 20 1.25 25.00T
Motl-8069HC-.5L RBF 600 Racing DOT 4 1/2 Liter 1 17.99 17.99T
MOSS-SSZ33C Stainless Kevlar Clutch Line VQ35 1 50.00 50.00T
TEI GSP24-FUAS1 Tein Mono Flex Coil Over Set 14kg 350Z/G35 1 1,820.00 1,820.00T
Labor-Mech Labor: Install Coil Over Kit 2.5 100.00 250.00
ST 86.646.06224 Stop Tech Stage II Upgrage 350Z/G35 Brembo Slotted 1 750.00 750.00T
Labor-Mech Labor: Install Brake Kit 2.5 100.00 250.00
Labor-Mech Labor: Bleed Brake Hydrolic System 0.5 100.00 50.00
Frg-FMAC-350Z-... Forge Motorsports Wastegate Actuator for APS TT 350Z 2 190.00 380.00T
Page 3
$23,004.54
Don’t fret … more comin Douglas…. Gotts baby here
Doug…… your good with numbers… help me out with this, cause I didn’t pick up a copy of the final invoice when I paid Sharif…. Why you ask …..because he and I are both people of integrity…. Doug.
6 piston stoptechs fronts
4 piston stoptechs rears
Staggered set of 19in volk te37’s
Set of PS2’s
Sharif’s slick 2 fan cooling unit
Tien flex coilover…. No controller…. Knew you’d ask
Reflash
Repaired feul tank …. Don’t ask
Previous set of rollers
Staggered set of TSW20in Nogaros
Toyo Proxus 4’s
Fenders rolled
And you know all about the audio….. apparently it should have been free.
I purchased the car new $36,000.00
Add all that up that’s like $100,000 Douglas…. Much to my chagrin.
Call it what you want maybe you need more details… I’ve got all night
for $100,000.00 you could bought a ZO6 vette or even the new ZR-1, ACR Viper, exige.....
I don't think someone would lie about spending that kind of money on a Z, but why? Everytime I look at modding I think hell just buy a vette or factory five cobra and keep the Z as a DD in time.
I don’t want a US sports car but definitely a Porsche GT2 or GTR ....one's 200g’s the other’s 18months away for us mortals.
Originally Posted by fightmoves
At z1
Parts $ Labor $
Shipping
Total $18,314.90
Parts $ Labor $
Shipping
Total $18,314.90
you paid $2,500 to install a TT Kit?
you paid $600 to install a $525 meth kit?
you paid $1575 for what exhast?
i am starting to feel more sorry for you that you got raped instead of you actually embelishing your numbers
let me go step by step here..
Look bro… I’m a business owner. I also own a metal fab shop. I could have done all this work myself. And I cannot stand people like you… you can always get a better price…. I’m sure you’re always the expert. I don’t have a problem paying a professional to do his job… it’s good for the economy. And if they stick me for a little, trust me I’ll pass it on to the next guy. I’m not going to embarrass either of us haggling over every detail. If I can’t afford it, I don’t do it. And last I checked you weren’t writing my checks, and last I checked I wasn’t short of cash. So maybe you should change your ways and the karma train will smile on you.
Lessons learned from those of you that haven’t killed yourselves yet
1. GO TO FORGED FIRST…. FIRST AND SECOND
2. set a budget and a timeline for your mods…. Or you’ll dump a ton of dough
3. Big power “Z”s are expensive… if you’re on a tight budget. May want to start with another car
4. you gonna lose you A$$ when you sell it… so keep it and love it
now … who wants to see my old lady's A$$?
thats some crazy $$ (i have respect for those of you who stick that much money into your cars). after takeing such a loss on my old B18 (bought for 8k put 7k into it, sold for 6300 two years later. ), im stopping at 300whp, then hopefully moveing on to something different like the new GT-R.
I usually don't post, but rather just view the threads, but after reading this thread I had to post. Fightmoves, you are the man. It's sad that you have to prove things to all these people/haters who really don't matter... But it's also cool that you are able to back up what you say if you choose to. Keep up the good work and congrats on your successful businesses, new baby, and hot girlfriend. I'm one to congratulate the next man because I'm happy with my life.. I guess alot of these guys aren't though... Makes you wonder!
LOL at this thread.
I feel for you OP. I have the same Catch 22 in certain social circles (you're either a braggart or a liar). I won't elaborate because the piranhas around here don't need to know that much about my personal life.
