burn out
Old Mar 19, 2008 | 06:36 AM
  #41
ZTUPID's Avatar
ZTUPID
Bolt on a turbonator, and do burnouts all day!
Old Mar 19, 2008 | 06:37 AM
  #42
Get_Zwole's Avatar
Get_Zwole
i still say use the brickwall may cost you a bumper but you can burn out anytime you want. especially if you have money like kayfunk and judging by your posts you two are comparable.
Old Mar 19, 2008 | 06:38 AM
  #43
onedirtyz's Avatar
onedirtyz
my car is dirty
i thought about it and it must be your blinker fluid.. when it gets old/dirty it starts adversely affecting the ECU. change it: http://kalecoauto.com/index.php?main...&products_id=6
Old Mar 19, 2008 | 06:43 AM
  #44
blasian's Avatar
blasian
I forgot... you need to let some oil out of your motor too. The manual recommends 5 quarts but its really a lie. Our motors perform a lot better with just .5 quarts.
Old Mar 19, 2008 | 06:47 AM
  #45
Tav's Avatar
Tav
Onedirty; no you've got that confused. Its defiantly his HORN FLUID duh . That or your muffler bearings are completely shot!
Old Mar 19, 2008 | 06:58 AM
  #46
Tav's Avatar
Tav
If he does that and drops out some oil; he'll have to be buying new tires by the day!!!!
Old Mar 19, 2008 | 07:03 AM
  #47
VO...'s Avatar
VO...
Administrator
he has seen the light!!!!! praise jebus!!!!!!!!!
Old Mar 19, 2008 | 07:11 AM
  #48
Fletch69z's Avatar
Fletch69z
This is covered in quite a few threads. Search again.
Old Mar 19, 2008 | 07:14 AM
  #49
onedirtyz's Avatar
onedirtyz
my car is dirty
hmm you know, i didn't think about that. OP, you definitely want to check ALL fluid levels.. don't forget, if you have heated seats, the heater fluid too. and radio... all these things are connected to the ecu and vdc controls. something's off and kapow! no burnouts.
Old Mar 19, 2008 | 07:19 AM
  #50
Nick204k's Avatar
Nick204k
2 Fast 2 Furious... Damn I wanna try.
Old Mar 19, 2008 | 07:50 AM
  #51
Get_Zwole's Avatar
Get_Zwole
kid must be a hogan.
Old Mar 19, 2008 | 08:13 AM
  #52
VO...'s Avatar
VO...
Administrator
Old Mar 19, 2008 | 09:06 AM
  #53
blazefast's Avatar
blazefast
wow, NOOB question...
You obviously didn't read the manual. On page 113 'Advanced Owners Only' it lists the sequence to unlock the ECU for 'happy fun-time do-rif-to walnuts explosion!' Note: You may need a JDM manual for the code. After legal action was taken against them in 2006, Nissan North America took out the code and substituted it with pictures of Nism0 bunny rabbits.
Anyway, the sequence is as follows:
Note: Fuel pump fuse MUST be removed for this to work!
Turn key to position II, then I, then II again. Then, while holding the key in the ignition position (you should hear a cranking noise), input the following sequence: left turn signal, right turn signal, brake pedal, brake pedal, stereo power on, select track 6 "Rick Astley - Never Gonna Give You Up", passenger window down 3/4, brake, brake, gas, hood release, volume down 2 clicks, Square, Circle, left, left, right, up, up, up, down, Triangle, gas, brake, DIP.
You must enter it within 33 cranks or the code will not work. If you hear 'Koni Adjustables' from the speakers, you did it correctly! If your battery died, try again, you did it wrong.
Hope this helps, but PLZ search next time!
Old Mar 19, 2008 | 09:09 AM
  #54
KAZ350Z's Avatar
KAZ350Z
Originally Posted by KAZ350Z
Damn, I remember trying to defend the younger guys on here when I first joined, but its all making sense now.... I apologize to everyone on the forum for these posts....I'm ashamed
However, you guys are ruthless. lol
Old Mar 19, 2008 | 09:16 AM
  #55
jray8's Avatar
jray8
try this.....
Old Mar 19, 2008 | 09:33 AM
  #56
onedirtyz's Avatar
onedirtyz
my car is dirty
OMG LOL. you are genius.. oooooomg... :dies laughing:
Old Mar 19, 2008 | 10:01 AM
  #57
VO...'s Avatar
VO...
Administrator
Rick Roll FTMFGDW...
Old Mar 19, 2008 | 10:02 AM
  #58
VO...'s Avatar
VO...
Administrator
Ruthless like a one-legged man in an azz kicking contest...
Old Mar 19, 2008 | 10:25 AM
  #59
RedLine 350z's Avatar
RedLine 350z
Find the next oilspill and dip your PHat tires to get it all lubed up. You can do massive burnouts and possibly build a fire for homeless people.
Old Mar 19, 2008 | 10:44 AM
  #60
kenpo_350Z's Avatar
kenpo_350Z
If he is I want the Hulks autograph.
