Lowest speed in 6th??
When I am just cruising I like to put it into 6th as soon as I can, to help with mpg. Once I am up to speed, I will put it into 6th at as low as 40mph. I just wanted to make sure that I'm not doing any damage. The RPMs are about about 1500. When I need to accelerate or go uphill I always down shift. I try not to run at higher PRMs than needed, but is there such as thing as running at to low an RPM?
as per the owners manual, I will shift as low as 38mph, thats actually their "recomended shift point". I guess thats how they get such good gas mileage. I forgot to put the clutch in once when stopping, did about 15 in 6th, the engine didnt seem happy, it was shaking a lil bit. as soon as it was noticable, I corrected myself.
How can you run at 40mph in 6 gear and claim to have any control? If you need to speed up to avoid something, you're screwed. Running your gears at 2500-3000 cruising rpms not only won't harm your car, it's safer.
There is no such thing as "light traffic" in the Seattle area (actually I live on the East Side (Bellevue, Redmond, etc.) and work in Tacoma). So you very rarely get a road by yourself.
I almost always drive in 3rd gear at speeds up to 35mph. Once I start approaching 40, I'll use 4th gear. I very very rarely use 6th on highway driving to and from work. I need the acceleration, which means I usually end up driving most of the way to/from work, on the highway at 65-75mph, in 5th gear (except for the occasional 4th gear pass... :-).
Does anybody out there know if you can damage the car by running in too high a gear?
Running a car at too high a gear is called "lugging" and it''s not good for the car if you do it a lot but I doubt you can do much immediate damage from doing it one time. Think of it this way: the entire weight of the car is refusing to allow the piston to go down as fast as it needs to after the spark plug fires. You really need to get extreme with it to hurt the car, though, and you will hear and feel it complain.
I haven't played with it much (never wanted to or was able to force myself to do so) but I think the RPM speed of lugging depends on how much gas you're giving it. If you're coasting it doesn't lug until you get idle speed or below, but if you try to accelerate at too low an RPM you will feel/hear it lug at higher than idle RPM.
FWIW
There is not such thing as running too high in RPM, but remember this little rule: avoid "constant" rpm's higher than 80% of the max rpm. So 80% of 6600= 5280.
But seriously, don't tell me you guys bought this car to run a "low gas mileage"??? It's a sportscar!!!
It runs a lot smoother in higher rpm's. I agree with davidh, I try to stay above 2500 rpm. The car feels better and SOUNDS better.
If I wanted a good mpg, I would buy me a VW Golf Diesel...
I drive with other cars... and even shifting like a granny at 38mph, I can accelerate just fine... no Im not winning any indy races in 6th gear, but what do I need 3rd for? so I can run into the civic in front of me faster?
I definitly get on the car when I feel like it, and when I do, Ill never hit 4th gear. but for regular driving, I dont need emergency acceleration.... thats just silly.
manual recommends for normal acceleration at around 2K RPM. I mean there's still power around 1,700 RPM's... can still accelerate at a modest speed. By 35mph and cruising, i go to 5th. at around 45mph is when i go 6th. For me, in California.. i try to save gas whenever i can. freagin $2.05 a gallon for Premium
Jeez, no wonder I never got over 20 mpg. The only times I've ever used 6th was during break-in (re the manual) and several times at 100+ mph. I usually cruiZe at 3000rpm, but have never had it much over 4000rpm (except when I missed a shift a couple of times). I thought the shift points listed in the manual were typos, a Nissan joke, or accidentally cut and pasted from the Sentra manual.
Paul Frere (and Phill Hill) in "Sports Car and Competitive Driving" recommend as follows:
"For minimum wear and tear the engine should also be kept in the middle revolution ranges, but not given full throttle on a high gear unless it is running at least at one-third of its maximum rotational speed, when the inertia forces partly offset the high gas pressure resulting from full throttle operation, transmitted to the bearings by the pistons and connecting rods. Very high rotational speeds will, however, result in very high inertia forces (which increase with the square of the rotational speed) with consequent high stresses on all moving parts. Slogging or hard pulling at low revolutions not only produces very high gas pressures but also may result in burnt valves while gas at high temperatures is laminated through them as they open and close comparatively slow."
I'm not sure if variable valve timing resolves this problem, but I'm going to follow the advice.
So, IMO, drive in the mid rpm ranges - about 2,100 to 4,200 rpm whenever possible or convenient.
bfleming, thanks for that info. It sounds correct and confirms my suspicion that driving in to high a gear (very low rpm) can damage the car. Cruising between 2200 and 4000 is where it soundZ and feelZ the beZt. Happy driving.
-davidh
-davidh
-davidh
-davidh
And I don't remember where I saw the thread but I've seen pics of a main bearing ruined by high rpm as opposed to lugging. They have distinct differences in the type of wear done. Lugging a motor will kill it if you do it long enough...
