What's wrong with " First to second Shift"??? anyone?
Old Apr 12, 2009 | 09:36 AM
DIGItonium's Avatar
DIGItonium
^ Haha I don't pay much attention to the tach while driving, unless I'm hitting cutoff. It's all about the feeling when you drive. You can shift regardless of what RPM you're in, but if you shift too slow at certain speeds the car will "jerk" to match the revs.
Old Apr 12, 2009 | 10:12 AM
foreveryoung's Avatar
foreveryoung
Originally Posted by kyx4n
its fine.. if you really want it to be smooth, just hold the clutch in slightly longer so the revs drop... if you shift at 3000 revs, then let it drop to around 2500 then you can almost drop the clutch and it should be quite smooth..
Yeah,its smooth doing that but don't you notice the guy behind you all of a sudden on your rear bumper???
Old Apr 12, 2009 | 10:25 AM
Chief2884's Avatar
Chief2884
I try to keep the car moving slowly enough so i can just take off in
2nd
Old Apr 12, 2009 | 10:40 AM
zettahertz's Avatar
zettahertz
if it pulls forward, you're letting clutch out too fast (faster than RPM drop), if it pulls back, then too slow.
Old Apr 12, 2009 | 04:35 PM
Orrah's Avatar
Orrah
I shift @ 1.5k rpms Granny here, get about 25/26 mpg in town though
Old Apr 12, 2009 | 05:37 PM
Z-Lover's Avatar
Z-Lover
Originally Posted by GHOST1207
Well it depends, does it jerk really hard or just enough for you to feel the shift? When I first started learning to drive it, it used to buck real hard, but now sometimes it's smooth and every once in a while I can feel it. Just watch your tach and remember where the rpm is once you're in second, then the next time you shift from first to second, watch your tach and try to let out the clutch when it reaches that mark. I'm not really good at explaining things, so let me know if I'm confusing you.
bro, i tried ur way of shift...it works ..lol.....now shifting to second is pretty smooth....sometimes it does the jerky motion a little ..but not as bad as it was before....lol..thanks
Old Apr 12, 2009 | 05:39 PM
Z-Lover's Avatar
Z-Lover
i heared u man!! i did as u said..and it works....when i shift into 2nd, i waited a bit til the rpm drops below 2500, then i released the clutch....shifting is smooth
Old Apr 12, 2009 | 05:41 PM
Z-Lover's Avatar
Z-Lover
yeah yeah...i noticed that....and sometimes i even got honk for that...i guess i drive too slow that people behind me can't stand anymore... but i don't care...i just drive the way i want...lol
Old Apr 12, 2009 | 05:43 PM
Z-Lover's Avatar
Z-Lover
hahahaha
do u get honks from people behind u ?
Old Apr 12, 2009 | 06:02 PM
bloodspoint's Avatar
bloodspoint
I felt like it was pretty jerky from 1-2 when I got it, but I've got it pretty smooth now. Seems like the keys are keeping the revs up and feathering the clutch a little more than usual on that one shift.
Old Apr 12, 2009 | 07:13 PM
Black Z Eddie's Avatar
Black Z Eddie
It used to bother me, but, I watch a lot of racing on TV and I can see and hear the cars jerk a little when they shift. So I just pretend that I'm driving out of the pit area.
I almost think it has something to do with the longish clutch engagement, at least for me.
Old Apr 12, 2009 | 07:58 PM
GSX-R350Z's Avatar
GSX-R350Z
Hah I'm not sure but I drive an 07 Z and sometimes it's hard to put it to 2nd gear.
Old Apr 12, 2009 | 10:10 PM
xpertool's Avatar
xpertool
Originally Posted by Z-Lover
i've been driving my stick Z for 10 months now...everything else is just fine besides the "first to second shift", i get dat damn jerky motion every time i shift from first to second.....ok, i shift mostly around 3k rpm....sometime a bit under , sometimes a bit higher...
second to third, third to forth, forth to fifth and etc are all pretty smooth..no jerky motion wutsoever....
can anyone tell me what did i do wrong? what's the proper way of shifting from first to second???
anyone get the same kinda jerky motion that i get?
please help!!!!!!
Well I get that jerky motion in the cold start at morning until the car warms up then it becomes smooth no jerky motion at all, I think its just that when its cold CLUTCH grabs harder so it tends to be jerky but you can still manage to shift smooth by letting out ur clutch little slower.
Old Apr 12, 2009 | 11:33 PM
GHOST1207's Avatar
GHOST1207
No problem, glad to see I finally helped someone around here, lol.
Old Apr 12, 2009 | 11:35 PM
Zian's Avatar
Zian
It is finicky. But as people have said, revving a little higher (thus the vehicle is moving a little faster) does seem to help. Assuming you are ok losing a bit of gas mileage.
Old Apr 13, 2009 | 03:01 AM
harvey a's Avatar
harvey a
Until you're more adept, you might try starting in 2nd gear.........
Old Apr 13, 2009 | 07:18 AM
VQpoweredZ's Avatar
VQpoweredZ
I had this same problem when I first started driving my 2006 MT Z. It is also my first manual car. When I first started shifting from 1st to 2nd was like hell. Now I have gotten it down to its either perfect or the car jerks just enough to feel the shift. Keep practicing. You'll get it down it takes a long time to perfect this car. One suggestion is that I feel this car almost "needs" more gas than other cars. I usually shift and when the clutch is in add the tiniest bit of gas and release the clutch slowly and that has gotten the shift to be more smooth (this is only in the 1st to 2nd shift). Hope I could help.
Old Apr 13, 2009 | 07:54 AM
  #38
Black Z Eddie
I'm pretty sure this is going to cause some stress on your tranny. I wouldn't recommend it. (assuming you weren't being sarcastic. )
Old Apr 13, 2009 | 08:11 AM
  #39
kno's Avatar
kno
2 years driving my z daily in Miami's bumper to bumper traffic, low rpm shift from 1st to 2nd and let the clutch out slow while applying just a little gas.
Old Apr 13, 2009 | 08:16 AM
  #40
kno's Avatar
kno
happens to me sometimes just hold the clutch change gears( i usually go back to 1st) real quick while holding the clutch and then go to 2nd again. i cant really complain that to Nissan because it happens unexpectedly and rarely.
