Any ideas on decreasing road noise....
I'm curious because we took a trip to Metrolina this weekend and it was kind of loud. I was wanting to do some kind of sound treatment to keep roadnoise out. Would an under coating do the trick? Any other ideas?
Yes, the noise level in my opinoin is to high when you have all the windos up. I noticed that the floor carpet is rather thin and allows the road noise into the car, I have done some under coating and it helped, my next step will be to insulate the floor board.
A high performance SPORTS CAR that makes too much noise.
BTW.....mine is still too quiet with my Nismo exhaust.........
Sorry, but I've been going to SPORTSCAR RACES for over 40 years, soooooooooo, I'm biased.
Originally posted by Jeff Holt
It sounds like it is coming from the back. It's not a defect, just road noise. More like a lack of insulation. The roads were also wet so I'm sure that amplified it some too.
http://www.soundproofing.org/sales/prices.html
Put it in Sunday but haven't driven the car since then. I may put some under the rear luggage compartment trim as well, but I'm starting with the simplest solution first.
Originally posted by MSCHOEN2U
I had my Touring undercoated by Ziebart, They are nationwide, I paid about 320.00
Did that help with the road noise?
Driving in the rain was the best test for the undercoating, I do not hear the tires or the water as much as I heard in the past.
If you can find a Ziebart dealer or someone similar they can show you the diffrence before they touch your car, I think you will be pleased with the outcome.
Good Luck
The tires on my Z suck bad. They just get louder and louder, but they are now wearing fine after being replaced by the dealer and getting a 4 wheel align. But they still make noise.
I blame the tire!
I blame the tire!
if you line the trunk area especially above the wheel well area it should help quite a bit with the road noise.
http://www.dynamat.com/
350Z_Al
Oct 29, 2020 07:44 PM
