Q For those in cold weather
Old Dec 2, 2003 | 05:13 PM
ZPower's Avatar
ZPower
Default Q For those in cold weather
You guys know how sometimes the windows freeze to the insulation on the door overnight from freezing rain turning to ice on the car? Will this damage the auto window motor? You know, when you open the door and the window tries to roll down the usual ~1/4-1/2"?
Old Dec 4, 2003 | 09:07 AM
archman350z's Avatar
archman350z
I wouldn't worry about the motor...they are normally protected from stalling and will shut down. I would, however, worry about the window. Since the window might not drop to clear the roof, be very careful opening the doors. Actually, I always keep an empty milk jug handy for the freezing rain stuff. Just fill it with the hottest tap water you can get, then pour it in the area where the window meets the trim. This also works great for the "lazy man's" way of de-icing windows!
Old Dec 4, 2003 | 09:14 AM
barrybell's Avatar
barrybell
I don't know how many times I've heard people pouring hot water on auto glass in the freezing temperates of winter and then wonder why the "tempered glass" breaks. Seen it many times in my years.
Old Dec 4, 2003 | 11:02 AM
onecoolee's Avatar
onecoolee
yeah, be careful with archman's lazy man method...have you ever seen tempered glass explode--NOT A PRETTY SITE !
Old Dec 4, 2003 | 01:54 PM
archman350z
Yeah, guess I should have been more specific: make sure not to douse the water onto the glass. Apply it in a small stream to slowly melt the ice. Also, use hot tap water, NOT boiling water. Tap water (140F) and ice (32F) average out to 86F, so it's not too bad of a thermal shock. If you're worried about it, you can use lukewarm water.
I've had to use this method several times after a freezing rain came through in order to get the doors/trunk open. I have yet to have a window crack.
Old Dec 4, 2003 | 05:02 PM
ZPower's Avatar
ZPower
mmmm..
Will the window actually hit the roof if the glass doesn't lower? Anyone ever try?
Old Dec 4, 2003 | 05:12 PM
ares's Avatar
ares
Veteran
it wont be a problem; just not ideal. it might catch slightly but only on the rubber seal, not the metal. youll be ok.
Old Jan 21, 2004 | 06:40 PM
clevr-z's Avatar
clevr-z
I wouldn't be too sure about that ... the first time it happened to me it completely freaked me out because it sounded like a seatbelt or something metal was caught between the door and the frame as it was closing. Upon closer examination, I realized that the sound was coming from the glass of the window [barely] hitting the metal lip above the rubber seal. It didn't appear to do any damage, but the glass definately hit the metal. I live in Minnesota, and although I don't drive my Z during any less-than-perfect road conditions ... this winter has been pretty mild and I've had the opportunity to drive her a few times so far. I've just gotten in the habit of gently pressing down in the center of the window to make sure that it goes down. If it doesn't budge, I roll the window down all the way, shut the door, reach in, roll up the window, and quickly pull my hand back out. It's not the most fun experience ... but that's what I get for washing my car in Minnesota in the winter.
Does anyone else have any ideas/suggestions?
Old Jan 22, 2004 | 05:44 AM
Vlad's Avatar
Vlad
My windows almoust never go down in winter... And the doors always close perfectly well without window moving at all... I wonder why I had to pay for that fancy feature wich doesn't work in winter and everything is fine without it...
Old Jan 22, 2004 | 05:03 PM
ZPower's Avatar
ZPower
Mine slams too. There seems to be a slight overhang of the roof over the window line. Sucks, noise is downright scary when you hit it and it can take a while to defrost, but so far, no scratches.
Kinda wished they would've designed this a little differently, i.e. no overhang. Then again, if Vlad doesn't hit his window, my door could be a little misaligned (though it seems to shut ok?). Haven't tried the passenger side and don't really want to either...
lapham3
Oct 7, 2022 03:15 PM
AbyteZero
Sep 22, 2015 09:17 AM
Darkspy
Sep 7, 2015 09:09 PM
