Rough Ride
Old Feb 1, 2004 | 05:33 AM
Philip's Avatar
Philip
Default Rough Ride
My track jarred me over bumps, I noticed by the tire inflation gauge that my tires when heated gain about three lbs. pressure, so I run 31/32 lbs cold and when my tires are heated they get up to recommended 35 libs and my car rides much better
Old Feb 1, 2004 | 10:28 AM
kovalf's Avatar
kovalf
Default Re: Rough Ride
The 35 lb recommendation is for cold tires. Running them lower will soften up the ride a bit, but at the expense of handling. Also, underinflated tires are subject to uneven wear and overheating when run at speed, but 3 lb shouldn't make a lot of difference. Monitor the tire wear on the outside edges for underinflation wear.
Old Feb 1, 2004 | 12:33 PM
Philip's Avatar
Philip
you are 100% correct, I filled my tires to 35lbs cold
350Z_Al
Oct 29, 2020 07:44 PM
hulkout
Apr 28, 2017 09:00 PM
ablaine
Nov 29, 2016 10:13 AM
Tochigi_236
Sep 27, 2015 03:40 PM
Darkspy
Sep 7, 2015 09:09 PM
