Voltage at cig lighter/aux or obd2 port
Old Nov 2, 2016 | 12:24 PM
Swaglife81's Avatar
Swaglife81
Default Voltage at cig lighter/aux or obd2 port
Just want to see what voltage readings you guys are getting at one or both ports with engine idling. I'm showing 12.8 to 13.1 but not sure what the obd2 port should be showing. I'm getting 14.4 at idle at the battery. So I'm praying I don't have a huge voltage drop.
Old Nov 2, 2016 | 05:32 PM
venture210's Avatar
venture210
check the FSM
http://www.nicoclub.com/FSM/350Z/
Old Nov 3, 2016 | 07:46 AM
PerfZ's Avatar
PerfZ
14.4 is correct at the battery when the car is running - that is alternator voltage. You are fine - everything runs off 12 volts more or less.
Old Nov 4, 2016 | 10:44 PM
Swaglife81's Avatar
Swaglife81
Appreciate. Never really took voltage off anything other than battery. Never needed to.
