Can I use this cleaner or has any one used it?
Old Nov 4, 2016 | 02:31 PM
Newusr's Avatar
Newusr
Default Can I use this cleaner or has any one used it?
Hello! i recently purchased a 2007 350z convt.
and i researched and searched and i see like 423432 different responses as to wether the the soft top is CANVAS, VINYL etc...
anyway i bought this cleaner https://www.amazon.com/303-30510-Con.../dp/B0002KKIR8
303 - Vinyl convertible top & tonneau cover care kit.
(303 - Protectant - interior and exterior)
The cleaner seems fine.....
However, the PROTECTANT is what I am worried about now from seeing so many answers....
it says its good for VINYL but not to use it for FABRICS (Canvas)
has any 1 used it?
Old Nov 4, 2016 | 02:53 PM
travlee's Avatar
travlee
Master
check out detailedimage.com, would be a better resource for you. 303 is good stuff though
Old Nov 4, 2016 | 04:20 PM
jhc's Avatar
jhc
General & Tech Moderator
^^^ Trav's advice is good, I use Detailed Image for everything.
Assuming these are legit 303 products and your top is OEM, you have the right stuff. Just follow the directions, you'll be fine.
I redid my top at home and went with canvas, just be clear you have the vinyl/plastic top.
Old Nov 4, 2016 | 07:48 PM
Newusr's Avatar
Newusr
thanks fellas!
Old Nov 5, 2016 | 03:32 AM
Timmy Tran's Avatar
Timmy Tran
I have a an 04 roadster. The original soft top is vinyl unless you have replaced it with some other material
