Code p1065
Old Mar 1, 2017 | 02:04 PM
Karwo Z's Avatar
Karwo Z
Default Code p1065
I got a code p1065 CPM backup circuit malfunction. I tried to reset the ecu and it dosent fix it. As i drive it runs rough at low rpms/startup and the check engine light blinks and sometimes dosent blink. Anyone know what could be the problem?
Old Mar 1, 2017 | 02:34 PM
rllynch1's Avatar
rllynch1
http://lmgtfy.com/?q=code+p1065+site%3Amy350z.com
Old Mar 1, 2017 | 04:31 PM
karlt's Avatar
karlt
One pin of the ECU is hot-wired to the battery to keep certain memory functions alive, even with the ignition OFF. A P1065 DTC means that the ECU isn't seeing the proper voltage at this pin. There could be a problem with the fuse, the wiring harness, or the connector, or the problem could be in the ECU itself.
Old Mar 2, 2017 | 03:48 AM
HCO_surfer's Avatar
HCO_surfer
This problem has occurred before if you have a scanner and clear the code it should take care of all problems. I've had that happen before and this is what fixed it. Have you had your battery disconnected for a while?
Old Mar 2, 2017 | 03:18 PM
Karwo Z's Avatar
Karwo Z
I tried clearing the code but it keeps comming back. Ill take karlts advice and go from there. Hope I dont need a new ECU LOL
Old Mar 3, 2017 | 06:46 AM
HCO_surfer's Avatar
HCO_surfer
Damn that sucks. Maybe try to reset the ECU by leaving the battery unplugged for a while. If all else fails Nissan could use their consult machine to pinpoint the issue. Idk even how much an ECU costs these days lol
Old Nov 10, 2020 | 06:52 AM
Mamiph's Avatar
Mamiph
The same thing happened to me and yes I did had the battery disconnected for about a week. Did the throttle position relearn now SEL comes on when I accelerate any Ideas?
