Question about TTA TE37s
Old May 22, 2017 | 03:47 PM
davidmrqz3's Avatar
davidmrqz3
Default Question about TTA TE37s
I don't want to start a debate between 18s or 19s just looking for a quick answer since I'm a little unsure about this. My car is on TE37s, the Tokyo Time Attack model. 19x10.5 +22 , square setup. I'm working on a custom turbo kit and from the research I've done... it seems 18" wheels are the best option for road racing. My question is, will I be fine with my current wheel setup? I plan on having some fun obviously when the kit is finished/installed, so can someone provide some insight and possibly confirm if my wheel setup is in the clear , thank you !
Old May 22, 2017 | 03:57 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Originally Posted by davidmrqz3
I don't want to start a debate between 18s or 19s just looking for a quick answer since I'm a little unsure about this. My car is on TE37s, the Tokyo Time Attack model. 19x10.5 +22 , square setup. I'm working on a custom turbo kit and from the research I've done... it seems 18" wheels are the best option for street racing. My question is, will I be fine with my current wheel setup? I plan on having some fun obviously when the kit is finished/installed, so can someone provide some insight and possibly confirm if my wheel setup is in the clear , thank you !
First off, you should take out your reference to street racing. Not condoned here.
Secondly, why should a change in diameter make a diff so long as the tire's contact patch is the same?
Unless of course, the definition of a "good drag set up" means lowering diameter, increasing size of the sidewall to soften it for better hook-up. In which case, 18s aren't going to be a huge difference.... probably best to go down to a 15 or 16 with overall tire diameter remaining as is.
Old May 22, 2017 | 07:02 PM
chatcher's Avatar
chatcher
If by road racing you mean taking it to a road course then you'll be fine. I track my 350 with 19 te's. Tires will cost more over the long haul but I am alright with the cost as I love the look of 19's.
Old May 22, 2017 | 07:06 PM
davidmrqz3's Avatar
davidmrqz3
No I meant street , I was asked to change it
Old May 22, 2017 | 07:08 PM
chatcher's Avatar
chatcher
Well I hope you change your mind about that
Old May 22, 2017 | 07:49 PM
terrasmak's Avatar
You can effectively act like an idiot with any size wheel on your car. Since there are no controls, timing and other stuff when actininh like an idiot, I wouldn't worry about it. Hard part is finding sticky tires in the size you will need.
Old May 22, 2017 | 09:32 PM
davidmrqz3's Avatar
davidmrqz3
Thanks !
Old May 23, 2017 | 04:30 AM
travlee's Avatar
travlee
Master
Dugan..... Dugan..... Dugan....
Old May 25, 2017 | 03:18 PM
HCO_surfer's Avatar
HCO_surfer
Are you stupid? Life isn't the fast and furious... I hope you don't wrap it around a pole.
