TPMS/BCM swapping issues?
Old May 27, 2017 | 01:23 AM
Bolivian86's Avatar
Bolivian86
Default TPMS/BCM swapping issues?
So my issue is the opposite of what most people have, I have a 2007 auto, I just replaced my tires and got new tpms sensor in all 4, but a week later I got a flat and the light didn't go off. So the I notice the TPSM light wouldn't come on when I start the car. I tried the relearn paper clip trick, but that didn't work and I swapped out the tire pressure receiver (antenna) that didn't work. Then I swapped out my 2008 manual BCM and install it into my 2007 automatic and it worked. So basically there is an issue with my BCM. My question is other than making new programmed keys or swapping out the key ignition from my 2008, would I have any issue swapping out the parts? Or is there a way to fix this without swapping things?
Just an FYI the 2008 Z is totaled that's why I can't drive it
