Suspension help
I am as noob as they come to the 350z world. I am not a noob to car mechanics however thankfully. I just purchased this three days ago. Previous owner told me it is on h&r coilovers and I can raise it a bit if needed, it is needed. My issue is the front only has coilovers and the rear is simply lowering springs. The tires as 235/40/18 on all for corners and the front is only a 1/4 lower than the rear when I measured from the bottom of the rim to the fender. I am looking for some input as to what is needed to get this thing off the ground a little bit more so I can drive it. The area I am from has terrible roads so this just cannot work. The body of the car isn't even the major issue. It seems like underneath is a tad lower than the body and I dont want to be ruining things driving it this low.
If I purchase and install the rear lower spring mount rubber pieces will that raise the rear a little bit? What I initially did was cut a 3/4 inch aluminum spacer and installed it above the spring where the adjustment nut would be. Kind of ghetto but does what the nut would aside from being adjustable. I plan on buying new coilovers in the future since these are tired but in the mean time if I could do this to gain a little more height that'd be great. It's almost at the ride height I'm shooting for
