Kevin Skene Build Thread
Old Jun 26, 2018 | 09:33 PM
  #61
Kevin Skene's Avatar
Kevin Skene
Originally Posted by Bak3rme
i see your rear main seal has been plastered with gasket maker. did u put that on or was it already on? mines leaking and i want to do it the right way but not wanting to spend the time to pull it all off. I like ur idea. hows it holding up?
I don’t think that using RTV like that is the best course
of action. Mine wasn’t leaking, but since it wasn’t leaking, i figured I’d put a jacket on it just in case. Like a jersey for riding motocross. It doesn’t do **** other than piece of mind
Old Jun 26, 2018 | 09:42 PM
  #62
Kevin Skene
Just a lil tease of my new head lights
Old Jun 27, 2018 | 06:29 AM
  #63
boamedt's Avatar
boamedt
Sweet lights. I love what you did with the front bumper and bash bar!
Old Jun 27, 2018 | 09:20 AM
  #64
bealljk's Avatar
bealljk
Originally Posted by Kevin Skene
[left] my new head lights
are you selling your old headlights?
Old Jun 29, 2018 | 02:55 PM
  #65
JTeeAre's Avatar
JTeeAre
Nice build thread, I can only imagine how much you're saving doing most of the work yourself. If I had a garage I think there's a good chance I'd have my own build thread too haha.
Old Jul 2, 2018 | 10:52 AM
  #66
Kevin Skene
Thanks man! Kinda wanna get a RB front bumper and cut it the same way..maybe a little less wavy though haha. Bash bar credit goes to https://www.instagram.com/heliarc_hustler/
It's an awesome bash bar, but definitely over built. It utilizes the crush pads attached to the oem aluminum bumper. So in the event of a crash, it should destroy those before bending frame rails...when i bought the bash bar, i asked the builder about it and he said only one guy has bent his frame with it, but he hit a tree at like 100+
Old Jul 2, 2018 | 10:54 AM
  #67
Kevin Skene
haha noooo i literally just took a grinder to the housing itself. Kinda wanna buy some cheap ebay headlights and do it again since my stock lenses are so scratched up
Old Jul 2, 2018 | 10:56 AM
  #68
Kevin Skene
Thanks man! I don't always put all the details in the thread since there are a million little things that come up. If you ever decide to do some of the work yourself and remember that I had done it, come ask! There were probably tons of issues that I ran into and can save you the time haha.
Old Jul 2, 2018 | 10:59 AM
  #69
Kevin Skene
Took my Z to an event @ Grange Motor Circuit here in Southern California. It's a SKETCHY go-kart track where if you go off track you start doing 50-50s and boardslides. Friend made this video. Not bad for my second event.
Car is at the shop getting an FD legal cage!!
I did have one "issue". I was hot lapping the car and noticed that for one lap, my clutch pedal went all the way down, then only came half way up when I let it go. It stayed like that for the rest of the lap but then started working fine afterwards.....thoughts?
Old Jul 12, 2018 | 09:59 AM
  #70
Kevin Skene
My 350z just got caged and up next is removing all the superfluous wiring that i don’t need. For example, the harness that goes from the rear hatch to the front (rear defroster, Bose amp, etc).
I am familiar that if you unplug the white ribbon on the climate control dials, the fans kick on 100% and blast my car with hot air from the engine bay.
Curious if there are other known electronics that will be ****ed up if unplugged? (like unplugging the gauge cluster and now the car won’t start).
I plan on turning the car on and off after unplugging/then cutting each connector.
thank you!
Old Jul 15, 2018 | 07:22 PM
  #71
Kevin Skene
Finally!!
Old Sep 5, 2018 | 10:08 AM
  #72
Kevin Skene
Been a little bit since my last post. I had my car caged and removing the sound deadening was a HUGE pain. Probably removed 30 lbs from the car though.
Painted the interior, got everything mounted and ready for my first competition!!
Qualified 4th and ended up 6th overall. Had a pretty gangster lead run, but on the follow run my clutch pedal got stuck to the floor and i couldn’t down shift to second. It was still a good day and pretty fun doing entry’s in 3rd!!
Old Sep 5, 2018 | 10:10 AM
  #73
Kevin Skene
Still having issues bleeding the clutch. I have a motive power bleeder but people seem to have conflicting beliefs when it comes to bleeding the clutch. Vacuum didn’t work for me the first time...clearly
so now it’s either gravity bleed or power bleed.
Anyone know the thread pitch for the slave bleed screw? My car is an 2003. Might slap on a speed bleeder for ***** and giggles
Old Jan 28, 2019 | 03:34 PM
  #74
Kevin Skene
Long time no update. Tons of modifications have been done to the car. Wanted to show off one of them.
I replaced my brake master cylinder with a wilwood 3/4 bore MC with the GK Tech booster delete plate. Also re worked all the lines in the engine bay with -3 AN braided lines. Making the lines was easy. I have my handbrake, clutch and brake reservoirs lined up on the side. This also included a wilwood brake proportioning valve. Tried to make everything clean. Pretty fun project.
ares
Repairing & Detailing (DIY)
Aug 9, 2015 02:32 PM
kgkeen101
NA Builds
141
Oct 13, 2013 06:54 AM
Tenn_SZ
Southern California
Apr 2, 2004 07:29 AM
